Online: Stuart, Hilly, Rextheute2022
12 inch mini ape kit
  • potluk
    potluk
    6 years ago
    Just purchased the black version of these for my street bob. They are supposed to be the same height as the original so I wouldn't have any issues with cables well the bars are the same but the risers are about 60 mm higher. Cables fit but are tight. Good news is that you can get a riser kit that is lower. So after paying $550 for the kit you then have to cough up another $200 for the risers that should go with the kit in the first place. And you can't buy the bars separately. On the positive side the bars look good and they are easy enough to fit.
  • micathia
    micathia
    6 years ago
    Quoting potluk on 21 Apr 2019 03:47 AM
    brand of the bar? I don't have street bob yet, but keen to know. Just in case. You never know when you get 20k extra cash in your life.
  • potluk
    potluk
    6 years ago
    Quoting micathia on 21 Apr 2019 08:43 AM
    harley davidson
