Online: tussuck, softfat
2016 Streetglide lower fairings
  • Paul4565
    Paul4565
    6 years ago
    Has anyone fitted any of these aftermarket  lower fairing (From US and China) out there, or should I stick to HD ones
  • Chaser
    Chaser
    6 years ago
    Quoting Paul4565 on 15 Apr 2019 01:31 PMedited: 15 Apr 2019 12:21 PM
    There was some chatter a while ago when someone did fit some.  General rule if they are from China, good luck!  Most ones from the US dealers are pretty good quality.  HD will be the best but you will pay for the privilege!
  • Nutty
    Nutty
    6 years ago
    Quoting Chaser on 16 Apr 2019 01:08 AM
    The 'Advan' Chinga copies are pretty good. Cheaper than OEM but not by a lot.
  • Paul4565
    Paul4565
    6 years ago
    Quoting Nutty on 16 Apr 2019 07:17 AM
    Are these the Advanblack ones from the US. Any Australian distributors?
    6 years ago
    Quoting Paul4565 on 16 Apr 2019 10:55 AM
    I got mine directly from the USA . They are good quality. Where you live Paul, if your tag is your post code were not far from each other you could come have a look at mine
  • TJU
    TJU
    6 years ago
    Gidday Paul 4565 ... like others are saying you get what you pay for ... but ... some of that China stuff is getting better ... i went with the Advan Black Stretched Bags and Stretched rear guard as well as some liners and the Colour match was spot on .
    I`m a bit fussy and there were what i called swirl marks in the bag surfaces paintwork but had them polished out by professional , and bloody perfect ... and not that it matters but ALL the bags were painted unlike Factory bags where in the back part where you don`t see are not .
    Now i don`t think i got any preferred treatment but someone here said they were only a little bit cheaper ... mine were Bucket loads cheaper than Factory ... at least half the price of Factory and that included shipping as well ... mind you i might have got a jacked up quote from Factory but all i know is they look great and they were heaps Cheaper .
    Will try and post a couple of pics for you to see Colour match ... Bags and lower rear guard are Advan Black ... Bag Lids and side covers and Tank of course are Genuine Factory .
    This is before the stretched rear fender .
    After the fender fitted ... with my bag blades on as well , just under the lids ... those things are amazingly bright .
    And the good old side view .
    I still like my Black Harley`s but this sure does pop in the Sunligt ... what Colour were you looking at for your lower Fairings .
  • Paul4565
    Paul4565
    6 years ago
    Quoting paulybronco on 16 Apr 2019 12:24 PMedited: 16 Apr 2019 12:25 PM
    I'm in NSW
    6 years ago
    Quoting Paul4565 on 17 Apr 2019 10:44 AM
    I'm in NSW
    LOL was taking a punt that 4565 was a postcode. Nevermind , can endorse the Advan lowers
  • Paul4565
    Paul4565
    6 years ago
    Quoting TJU on 17 Apr 2019 03:18 AM
    Nice ride, looks good in photos. Mine is Vivid Black as far as I know. Think I'll probably give the Advanblack ones a go. Can get from states for around A$500. Been told the HD ones are over $1000
  • Paul4565
    Paul4565
    6 years ago
    I'm in NSW
    Quoting paulybronco on 17 Apr 2019 10:49 AM
    Thanks anyway
  • Odin
    Odin
    6 years ago
    I got mine from Advanblack. for a 2016 Streetglide Special
