Online: brucefxdl
Big Brake Kit
  • EasyR Australia
    EasyR Australia
    6 years ago
    Sorry we havnt posted in awhile.
    Forum Special only
    15" Big brake kit AN-02-990  RRP$ 462.00 down to $350.00 for forum members
    https://www.easyr.com.au/?rf=kw&kw=an-02-990
    Give us a call on 07 3216 2251
  • Birtyyy
    Birtyyy
    6 years ago
    Got this to suit 2018 + Softail?
  • Sugar
    Sugar
    6 years ago
    Happy with mine. ??
  • Grease Monkey
    Grease Monkey
    6 years ago
    It's a good look, how does it compare to stock braking wise?
  • steelo
    steelo
    6 years ago
    What are you thinking gm!! It’s never been about improved performance.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting steelo on 12 Apr 2019 01:00 AM
    Haha, true
  • noctm
    noctm
    6 years ago
    Quoting Grease Monkey on 11 Apr 2019 11:10 PM
    probably no different, the rotor contact width is the same and the caliper hasn't changed. there might be a slight improvement in rotor cooling but i doubt it. it just looks cool.
  • Soapbox2627
    Soapbox2627
    6 years ago
    There would have to be better braking as the wider leverage and more friction per revolution
    But I have been wrong before
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Soapbox2627 on 12 Apr 2019 03:55 AM
    I was thinking the same Soap
  • steelo
    steelo
    6 years ago
    Why did they replace rim caliper brakes on bicycles then? So there!
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting steelo on 12 Apr 2019 05:18 AM
    Because they ugly haha
  • Nutty
    Nutty
    6 years ago
    Braking effort = Frictional load x rotor diameter
    Provided the pads don't overheat the braking force increases as the rotor diameter...or...for the same braking force the lever effort decreases as the inverse of the increased rotor diameter. Anyone who's ridden a rim-brake Buell knows how they work. :-)
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Nutty on 12 Apr 2019 06:39 AM
    All things being equal
  • Sugar
    Sugar
    6 years ago
    For me there was a large difference, much better than stock. Lot more confidence when in the twisties that’s for sure. Would I do it again? Definitely.
  • Benno
    Benno
    6 years ago
    I put the non wave kit on my wide glide a couple of years ago, I felt a noticeable improvement. I put a set of sintered pads in at the same time but removed them and put organic back in, the sintered pads are to harsh on the disc, I thought braking was no different between the pad varieties. I posted pics and a review titled Ness Big Brake Kit if you want a gander at it. I think they are a good look and work well.
    Benno
  • noctm
    noctm
    6 years ago
    that makes sense, didn't think about that
  • Sponge Boy
    Sponge Boy
    6 years ago
    Quoting noctm on 12 Apr 2019 02:57 AMedited: 12 Apr 2019 02:57 AM
    Yes surface area is the same but the increased diameter creates more leverage and therefore increased force; hence better braking power. You can actually feel the difference.
  • Sponge Boy
    Sponge Boy
    6 years ago
  • Ricca
    Ricca
    6 years ago
    These are great on stock fork legs, i had the inverted harley forks and didnt want to fit even with the bracket Plus using the 6 pot PM breaks didnt like it was hitting the Wave part.
    Slight Mod and was able to fit it to a breakout looks dope! ( on stock breaks)
  • bloodog
    bloodog
    6 years ago
    Quoting EasyR Australia on 11 Apr 2019 04:14 AM
    Forum Special only
    Thanks EasyR
