Online: Humbug, B0nes
Engine light P0661
  • Fxdb2007
    Fxdb2007
    6 years ago
    Gday
    My Street Bob has started showing me an engine light and the above code - I know it stands for intake solenoid open - however I do already have the Terminator doodad on it.
    I have tried a few different resistors from jaycar and no luck so was hoping to purchase another Terminator thing - anyone know where I can get one? I've seen "bigjoechoppers" mentioned on here when I did a forum search but it doesn't appear to be active anymore.
    Alternatively is there anything else that could be causing this light?
    Cheers!
    Matt
  • Grease Monkey
    Grease Monkey
    6 years ago
    eBay has them, superbike au used to sell them, dunno if they still do or not, worth a look perhaps.
  • Fxdb2007
    Fxdb2007
    6 years ago
    Thanks mate - didn't think of eBay.
    I know it's not harming anything but it's annoying and kind of embarrassing to ride around with the check engine light on!
  • Fxdb2007
    Fxdb2007
    6 years ago
    So I bought the plug shown from eBay (great seller btw, shipped same day and it arrived in a week, even taking easter into account). Anyway I'm still getting this engine light, same error code code. Anyone able to shed some light on how I could remedy this? Incredibly frustrating....
  • Grease Monkey
    Grease Monkey
    6 years ago
    Quoting Fxdb2007 on 24 Apr 2019 11:18 PM
    What tuning software are you using?
  • Fxdb2007
    Fxdb2007
    6 years ago
    I'm not using a tuner, bike has a FuelPak though.
    I'm checking the code by holding the odometer reset button in whilst turning the ignition on. I reset the ECM after installing the resistor thingy, so I know it's not a historic code.
    Matt
  • Grease Monkey
    Grease Monkey
    6 years ago
    Copy that, which one? FuelPak 1-2-3?
  • Fxdb2007
    Fxdb2007
    6 years ago
    Not sure which version, but this one with the led display.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Trying to work out if there is a setting in the calibration you are using that will affect it, not real familiar with FuelPak but did have a pciii once so I get the idea, what selections did you use for your exhaust?
  • Grease Monkey
    Grease Monkey
    6 years ago
    This is what I'm rabbiting on about
  • Fxdb2007
    Fxdb2007
    6 years ago
    This is how I've got it configired. I also used a map for the same pipes without baffles. Doesn't affect it. Bike runs great! Except maybe a little rough at idle. Might up setting 17 by 2 or 3, which is the "hot idle af" setting.
  • Grease Monkey
    Grease Monkey
    6 years ago
    Yep nothing visible, that resistor should of fixed it, I don't know the answer mate, I tried Google for awhile trying to get mode information but they bloody cagey about it, best I could come up with is contact them and tell them what you have and what's happening, there might be a mode that will sort it, there might not either but worth a try,
    Be interested to hear what they say though.
  • Fxdb2007
    Fxdb2007
    6 years ago
    Thanks man. I'll contact them. I was also thinking of lifting the tank to check for shorts or breaks elsewhere along the wires.
    Failing that I may have to Bute the bullet and go see the dealer, or just ride it! Dealer didn't seem to know much when I called them about it though.
  • Fxdb2007
    Fxdb2007
    6 years ago
    I've also got my eye on a powervision, so that might be a good option too.
    6 years ago
    Quoting Fxdb2007 on 26 Apr 2019 09:22 PM
    Love my power vision
  • Humbug
    Humbug
    6 years ago
    Quoting Fxdb2007 on 26 Apr 2019 09:21 AMedited: 26 Apr 2019 09:21 AM
    Wow that’s an old version compared to what I have.
