Dyna wide glide risers
Vrodvrod
6 years ago
Can anyone help I am after some pullback risers 5-1/2 to 6 inch risers with 1 inch pullback to fit 1-1/4 drag bars for my wideglide. I know Redzilla have a set, would prefer to purchase in Australia.
robots
6 years ago
What model wide glide
Vrodvrod
6 years ago
2014 fxdwg
Vrodvrod
6 years ago
Ratbob
6 years ago
As you probably know HD wants too much but maybe be patient, I recently bought a set of WG risers and bars for $130 on Ebay. Guy took em off from new. HD quoted $750.
robots
6 years ago
Try HD pullback risers. Think about 280$
Your bar goes to 1” at grips and riser
Grease Monkey
6 years ago
Type "Harley Risers" into Gumtree and narrow the search to motorcycle parts, heaps on there, maybe the ones you want.
Vrodvrod
6 years ago
Thanks for your comments
Sparra
6 years ago
As Hilly said there is a pair on Gumtree now...My 2010 was 1.25 and only reduced at the grips...
