Online: Hilly, speedzter, Uncle Ho, Merv
Shelf life of Screaming eagle synthetic oil?
  • Far Canal
    Far Canal
    6 years ago
    Anyone know what the shelf life is on this stuff?.
    I can't see an answer on the net.
  • Nutty
    Nutty
    6 years ago
    Quoting Far Canal on 02 Apr 2019 07:01 AM
    It depends on ester content FC. Full-syn 2T premix oils degrade if exposed to air because of the volatile esters used. I presume you're talking about SE full-syn 20W50 motor oil...it'll last virtually forever if the container is full. Most quality ester-based full-syns have a sealed cap so they'll keep indefinitely. A bit of Glad-wrap under the cap and they're fine for years.
    6 years ago
    Quoting Nutty on 02 Apr 2019 09:47 AMedited: 02 Apr 2019 09:49 AM
    With you Nutty
  • Soapbox2627
    Soapbox2627
    6 years ago
    Oil
    sat in the ground for 10,000,000 years
    IT GOES OFF????
  • Ratbob
    Ratbob
    6 years ago
    Quoting Soapbox2627 on 02 Apr 2019 11:01 AM
    Oil
    IT GOES OFF????
    Hey Soapbox, fucking hilarious, never thought of that, er, accept that synth is kinda new. No matter still fucken funny.
  • keith
    keith
    6 years ago
    Temperature controlled would be beneficial on any product, get turned over every 6 months by me ? Good question FC, ripper answer by Soapy !
  • Nutty
    Nutty
    6 years ago
    Oil
    IT GOES OFF????
    He he. Ripper.
    Q) What's black and tells you to fuck off?
    A) Crude oil.
    6 years ago
    Mobile One has a shelf life ( use by date.
  • Nutty
    Nutty
    6 years ago
    Quoting Krash Kinkade on 02 Apr 2019 09:40 PM
    I spoke to a tech-chemist mate at Mobil about this KK. Mobil testing has found that the plastic oil containers breathe, no matter how well they're sealed. This causes the detergent component of the oil (which is based on a very reactive metal, sodium, phosphorous, etc) to partially oxidise over time, decreasing the detergents' efficiency. To avoid this issue Mobil package their aviation and race-spec products in sealed steel containers. I guess SE are onto the same issue.
  • Far Canal
    Far Canal
    6 years ago
    Krash, have you ever noticed roughly how far ahead the use by date is?. Like is it several months or several years. The normal 4 litre SE Synth oil containers don't have a use by date on em that I can see.
