Online: Hilly, speedzter, Uncle Ho, Merv
Which bearing?
  • mickle
    mickle
    6 years ago
    Take the wheel with you to your Bearing supplier, he will ensure the correct sizing and may even fit them.
  • Crebbo
    Crebbo
    6 years ago
    Would be a 1 inch axle take in to ALL RV Ulladulla they should have what you need.
  • DocGreen
    DocGreen
    6 years ago
    have never had a bearing problem personally, but heaps of guys recommend 'all balls racing' bearings - think easyr (sponsor) sell them, maybe have a look on their site or give them a ring.
    DocGreen
    6 years ago
    Bearing supplier won’t fit your bearing   That’s up to your mechanic/ yourself  don’t forget
    You will need to get the right inner hub bearing spacer  for what size axel / hub/ bearing your running
    And fit the disc side first till it is seated  than the pulley side   .
    I run nsk bearings but in 3/4  from my bearing suppler  and there like  $8.00 each
    Not  not  $30.00  because thay come in a HD bag  but the nsk shit all over the HD quality my 2c
  • keith
    keith
    6 years ago
    Quoting perthhog on 28 Mar 2019 10:23 AMedited: 28 Mar 2019 10:28 AM
    Statewide Kewdale Road ?
    6 years ago
    Quoting keith on 28 Mar 2019 06:50 PM
    Yep that’s statewides  head office have been there a few times over the years  if
    My local  bsc  doesn’t have what I’m after   By memory there open  Saturday mornings too
