De CATed Dyna header for sale
Ratbob
6 years ago
From 2011 Wideglide, Catalytic converter removed, new pipe wall installed to make it a true twin pipe system then ceramic coated inside and out.
Used to test muffler designs so little road use. No marks from heat shield clamps (not used).
It is not designed to be used without heat shields, the ceramic coating is more about keeping the gas temperatures consistent rather than dramatically cooling the pipe.
Cost $600 to make, Terry at Redline Exhaust in Adelaide did the fabrication. No longer needed for testing so $200.
I'm happy to pack and send at your cost or meet up with an S.A. buyer, COD.
Ratbob
6 years ago
Bump
Ratbob
6 years ago
Bump while the subjects on topic.
