Online: Bullshark001, Stuart, Hilly, Rextheute2022
Washing and Drying your Bike
  • Bigfella
    Bigfella
    6 years ago
    There have been a few threads on bike washing several years ago, can't find anything recent so wanted to get some opinions and ideas for this day and age.
    I'll start with I'm generally a lazy count (without the "O"), so the least effort for the best result is my go. I've got away with washing my bike once in 4 months, I used HD sun wash, micro-fibre wash mitt and cranked up the 18V Bosch blower to dry it, followed by a few detailing wipes. I was happy with the result. The dealership washed it for me at the 1st service using a hot wash pressure cleaner and "snow foam" as detergent. Then dryed it with a run of the mill pet dryer with a low heat setting and it come up a treat.
    What is your washing/drying regime?
    What are you guys using as detergent and also to dry it?
    Is there a decent pressure washer brand and model that you would recommend?
    If you use a dryer what brand and model do you use?
    Thanks in advance
  • Wholehog
    Wholehog
    6 years ago
    Any old auto soap and any old sponge ....Sometimes use compressor to dry it off.
    As my bike is black denim I use window cleaner to wipe over the tank and guards and I use Mr Sheen on any thing else.
    6 years ago
    Wash , then blow off with compressor , then wipe off , then take it for a ride & another wipe off.
  • Ratbob
    Ratbob
    6 years ago
    Pressure cleaners are capable of blowing the coating off fins and engine cases and pushing water where it’s not wanted. Wouldn’t let one near my bike.
    Blow drying ok but again wouldn’t get too close even they can push water into wheel bearings.
  • brucefxdl
    brucefxdl
    6 years ago
    for a start a quick spray on the bugs with bugger off,a lot of people dont like ct 18 ,but thats what i use with a spot sprayer,let soak/dry,then normal car wash,good rinse [ no hi pressure cleaner here as well,although i have one its for the 4wd's]. drip dry for a few minutes.then shammy and micro fibre clothes.now and again i use turtle wax "wax and dry",comes up well with this. i try and avoid washing in hot sun. imho, pressure washers have a place but it's not around black finish engines,wheel bearings, cables or instrument clusters.the ct 18 does a good job on brake dust and hard to reach areas.this all might seem a bit over the top,but it doesnt take long.
  • mickle
    mickle
    6 years ago
    Soak overnight with CT18 then hit it with the pressure washer and chamois, comes up like new and never fucked anything on the
    CVO and it has a lot of things that can be fucked up.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    I hose the bike down a with gentle  spray setting and garden hose. Wash with a wax free car wash, sponge and two buckets, one with the suds the other the rinse water. Do tank and paint first, then progressively dirtier bits with wheels last, hose rinsing as I go, then a good wash off when done.
    Dry with chamois.
    Then polish and wax coat.
    I do the alloy and chrome work alternative washes, so only half the polishing each time. I found if I do it regularly it is very easy and quick, the first time took a lot of time and effort because it was pretty bad. Yet to try the Mr Sheen, but sound like a good idea especially on the rocker box covers.
    It usually takes me around an hour all up if I am not too OCD.
  • Soapbox2627
    Soapbox2627
    6 years ago
    Snow storm, wash off with a sponge then chamios dry, that was the Train,
    now the Road Glide Sp. will get the same
    6 years ago
    Quoting Soapbox2627 on 24 Mar 2019 01:28 AM
    Looks like a male elephant likes your bike!
  • mickle
    mickle
    6 years ago
    Quoting paulybronco on 24 Mar 2019 08:16 AM
    Nahhh just Soapbox.
  • Bigfella
    Bigfella
    6 years ago
    Great tips guys, I really appreciate it.
    Now onto the polish.......
    I've got a splash mark on my front rim, looks like someone "batted one off" on the rim! Can't figure for the life of me where da fuk i picked that up. After a few people mentioning "Purple" on this forum I brought a bottle. Gave it a go yesterday, it helped get rid of most of it, but you can still see it.
    What do you guys use and recommend?
    Looking good @mickle
    Going to give this "SnowFoam" a shot, thx @Soapbox2627
    If no go I'll give Bowdens a crack, thx @Hot and Heavy
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Autosol polish. One for alloy and another for chrome work.:) A tube lasts for ages. Not surr what ur rims are, mine are bare alloy.
    Thanks for the tip H&H I have some swirl marks on the tank. Might give it a crack.
    6 years ago
    I may be a little OCD but then again my 09 Sporty still looks better than it would have on the Dealership floor and that's with 100K under the belt.
    Search for the term "Scholl" and you will come across a couple of threads where I have put down a detailed process for washing and paint correcting in a thread called "my polishing tips'.
    No pressure washer used normally, but ANY pressure washer will do the trick, just remember to not point it at the wheel bearings.
    SOAPs are critical so get a good one!
    My goto dryer is now a mains powered leaf blower I got cheap on Gumtree (I also have a battery one but its only 1/2 the power of the mains one and its noticible)
    Its not rocket science, but its definitely a case of you get out of it what you put into it.
  • Jay-Dee
    Jay-Dee
    6 years ago
    Quoting Bigfella on 25 Mar 2019 05:59 AM
    I've always used Mothers metal polish with good results and would still recommend it.
    I tried some of the California Purple after reading it on here and to be honest wasn't really that impressed with it. I also gave the Bowden's metal polish a crack recently just to try it and it's fucking awesome, especially on bare alloy or chrome.
    The water marks like you're talking about are really hard to get rid of though, I have some on my V-Rod wheels from before I bought it and I haven't had the patience to get rid of them completely. The Bowden's or Mothers has given the best account, but they still need more work when I can be arsed.
  • T4
    T4
    6 years ago
    This shit does a good job on stubborn stains when I can be bothered
  • Bigfella
    Bigfella
    6 years ago
    These are tussuck's tips above (hope he doesn't mind) from a different thread he mentioned earlier. Great info, this is right up my alley, spend the time to get it right and follow up with a little maintenance down the track.
    Would any guys in Melbourne be interested in doing the Waxit $100 detailing workshop on a Saturday morning, next one is 13th April? Maybe go for a rip in the afternoon....
    6 years ago
    Bigfella , on the wheels , if they are chrome , & on bare Alloy ss100 is best I've tried.
  • Kato
    Kato
    6 years ago
    Quoting mickle on 24 Mar 2019 12:37 AM
    I love the simplicity of that saying
  • 18CVO
    18CVO
    6 years ago
    All bowdens products. Bugger off soak to most of anything facing forward. Wheely clean around front wheel fork and calipers. Snow blow after and gentle pressure clean after with compressor and dry with bowdens big green cloth to finish. I try not to wash by hand with sponges nor chamois as they produce swirl marks and paint damage....
  • Smokey61
    Smokey61
    6 years ago
    Quoting Ken in Cairns on 25 Mar 2019 11:18 AMedited: 25 Mar 2019 11:20 AM
    Try to avoid abrasive polishes on chrome. After washing, I use Mr Sheen on the chrome.
