Online: Hilly, speedzter, Uncle Ho, Merv
how to remove the hose cover from a Night Rod
  • ralphski
    ralphski
    6 years ago
    just wondering how to remove the hose cover item 18, so i can remove the hose item 12 from a Night Rod
  • brucefxdl
    brucefxdl
    6 years ago
    looks the cover has a built in hose clamp...may be.
  • ralphski
    ralphski
    6 years ago
    looking at the drawing, it looks like the 3 off items (# 15 ) are permanent clamps of some sort, and can't be removed.
    unsure
  • Far Canal
    Far Canal
    6 years ago
    Is there no mention of this in the relevant workshop manual?.
  • Phatty
    Phatty
    6 years ago
    Take the upper hose clamp off and it will pull out.
    Loosen the bottom hose clamp and then undo the waterpump cover bolts and remove.
    You can take the hose off.
    6 years ago
    What the hell is a vrod?  and simply undo the clamp to remove the cover, or if its a spring then slide it away.
