Online:
tussuck, softfat
Skipping songs on Boom 6.5
ducatidan
6 years ago
All of a sudden I can no longer skip songs when streaming songs through my phone.
It first ist connection to my phone so I cleared it and reinstalled and now I can’t skip songs.
Any ideas on how to fix, as I can’t find the boom 6.5 manual?
DocGreen
6 years ago
Quoting ducatidan on 17 Mar 2019 05:46 AM
Ducatidan, turn your boom on and go to settings, audio or radio - cant remember. top left button should be on seek. Its probably on scan, select it and change it to seek.
Think you can get an electronic copy of the manual online also, one of the guys posted the address recently so should be easy to find.
HTH
DocGreen
ducatidan
6 years ago
Cheers DocGreen.
That worked. Not the same way, but it work all the same.
Thank you
DocGreen
6 years ago
Quoting ducatidan on 17 Mar 2019 06:33 AM
Cheers DocGreen.
Thank you
You're welcome mate
DocGreen
