Online: WideglidingNZ, softfat
Passing/Fog Lights
  • Rumpig_63
    Rumpig_63
    7 years ago
    Just wondering if anyone has looked for or have been able to find spotlights to replace the 4.5” passing/fog lights at all?
  • keith
    keith
    7 years ago
    Quoting Rumpig_63 on 04 Mar 2019 09:08 PM
    There is a old tread on here with a converserion , after market ad-bolt on.
  • Chaser
    Chaser
    7 years ago
    If you are just after the lights themselves, every man and his dog sells them, and a lot cheaper than HD has them for too. Try Amazon for a generic or google SCOOT lights for harley. Excellent service and fast delivery.
  • Krackers60
    Krackers60
    7 years ago
    HogLights are up in Queensland and have a quality product.
    I purchased their Halo spotlights to replace my HD originals and am exceptionally pleased.
    There's plenty of options out there if you have the time to look.
  • keith
    keith
    6 years ago
    I've just recently bought a 2003 Road King with the factory originals fogs on it, will do a conversion at some stage also. Many after markets out there.
  • JR888
    JR888
    6 years ago
    I've got the original clear lights for a 2018 Road King if they're any good to you.
    I'm on the sunny coast at Maroochydore.
  • Rumpig_63
    Rumpig_63
    6 years ago
    Quoting Krackers60 on 05 Mar 2019 02:24 AM
    would you have any pics of your set up at all?
  • Robbo_Townsville
    Robbo_Townsville
    6 years ago
    I can vouch for hoglights. About 400 bucks cheaper for an 2017 Ultra headlight. Come with unbreakable cover. Give them a look.
  • wildchild
    wildchild
    6 years ago
    LED FACTORY MART.
    Planned on get the OEM LED's and was blown away on price for LED head light and passing lamps, next trip to dealer I was going to get them until in the meantime I come across LED Factor Mart.
    LED Head Light and Passing Lamps with Bezel under $200 AU delivered.
    Okay, that got my attention....I though for under $200 they would be worth trying.
    After installing them, wow what a difference in brightness, they make the OEM head light look yellow.
    These lights are a crisp white light.
    Head Light. Luminous Flux 4000LM @ High Beam, 3000LM @ Low Beam.
    Passing Lamps. 1260LM.
    https://www.ledfactorymart.com/collections/harley-7-inch-headlight-without-bezel-1
  • Baloffski
    Baloffski
    6 years ago
    wildchild they look good, kinda looks like an angry  insect. Possibly just my demented take, but can imagine they be bright as.Keith ya Roadie lighting has that classic original old loo, which is cool as, but as you say function is the way to go. LED's are amazing lights.
  • gidgi
    gidgi
    6 years ago
    Quoting wildchild on 18 Feb 2020 03:41 AMedited: 18 Feb 2020 05:09 AM
    LED FACTORY MART.
    cheers for the link Been after some Led `s to replace my foggy looking headlight for a while now keep forgetting $181 au delivered
  • gidgi
    gidgi
    6 years ago
    LED FACTORY MART.
    Quoting gidgi on 18 Feb 2020 07:50 AM
    Hi when purchased yesterday it said I would need a new headlight ring to fix LED firmly , could someone explain what the deal is with this, is it a different size or shape & can I use or  modify the original? thnx
  • wildchild
    wildchild
    6 years ago
    LED FACTORY MART.
    Quoting gidgi on 19 Feb 2020 02:24 AM
    They may be talking about the Bezel.
    You will need to replace OEM Head light housing with the Bezel for LED light clearance.
    Send them a message through messenger, they are quick to respond.
  • gidgi
    gidgi
    6 years ago
    Quoting wildchild on 19 Feb 2020 05:34 AM
    cheers Wildchild ,sorted mate cheers
  • Dale
    Dale
    6 years ago
    Bought these cheap Chinese knock offs of Ebay and had them on the Heritage for about 5 years till I sold it. Gave out a better light than my Mtes genuine HD daymaker. He swapped his out and bought these. Cost me under $200.00 for all 3
  • gidgi
    gidgi
    6 years ago
    Quoting Dale on 22 Feb 2020 12:26 AM
    looks good Dale I went with the dark lenses, mine are coming from US but probably Chinese made ,still ! good price me thinks
