Online: beaglebasher
How much tyre clearance
  • Mr.Mow
    Mr.Mow
    7 years ago
    Is required between top of the tyre and the guard?
    My sportster chop runs a 130 16 on the rear, previous owner put a Shinko 777 on it, a rather modern tyre, outer diameter is 25.2 inches.
    Problem is it looks rather out of place and modern on a vintage bike.
    Looking around, both the Shinko super classic and the Avon speedmaster II measure in at 26.3 (and seem to be the only vintage style tyres I can see for a 16”)
    When the bike was built it was built around the crappy Shinko, means there’s about 12mm clearance, those vintage style tyres also require a similar distance, so yes technically it will just fit, but how much will a tyre expand at speed?
  • brash
    brash
    7 years ago
    My sporty build I had down to approx 5mm, never touched but wasn't ideal.
    The garden hose technique is a good rule of thumb, Jam the hose in, plonk the guard on top and fab from there. I used that for my chopper build with a Shinko classic and looked the goods.
  • Baloffski
    Baloffski
    7 years ago
    Quoting brash on 03 Mar 2019 02:46 AM
    I shall pipe up here with NO information. But that bike is beautiful. Not what I do but give 10 years, would peg her.......
    She is on my screen saver.... Beautiful bitch.
    7 years ago
    The width of a garden hose is what I see on the box.
  • Mr.Mow
    Mr.Mow
    7 years ago
    Quoting tussuck on 03 Mar 2019 10:39 PM
    Sigh.. so I’m stuck running a modern profile tyre, unless we fabricate a whole new rear guard, sissy bar and seat.
    7 years ago
    What about a 777 with whitewalls?  I'm in the same boat as I'm chopping the Sporty and the Night Dragons are going to look out of place in 12 months time as I near completion; but in the meantime I enjoy the traction.
    I am looking at a set of 777 tyres in the long run, however I will be retaining shocks on the rear (albeit fully covered chrome units) as I need to ride every day to work.
    My compromise was a set of modern whitewalls.
  • Mr.Mow
    Mr.Mow
    7 years ago
    Quoting tussuck on 04 Mar 2019 03:54 AM
    Nah, not into white walls at all! Whitewalls for me suit certain types of bikes but not choppers!
    To be fair the 777 is an ok tyre, just on a vintage bike they’re weird lookin.
