Online: Hilly, speedzter, Uncle Ho, Merv
Paintless dent removal
  • rustom07
    rustom07
    7 years ago
    I have two small dents in my tank on my 2016 street glide and wanted to know if anyone has attempted or had any luck useing the glue tabs to try and pull a dent out? The dents have not gone through the clear coat.
    7 years ago
    Tanks are tough to pull dents out of, pretty strong steel
  • steelo
    steelo
    7 years ago
    I wouldn’t risk it yourself. Get one of those mobile crowds to come out. They have tools which can tap out dents from inside without stretching the metal. Amateurs tend to try and pull dents out quickly rather than finessing them out. Good luck.
    7 years ago
    Quoting steelo on 01 Mar 2019 11:00 PM
    Have to agree totally
  • steelo
    steelo
    7 years ago
    Thanks for support pb but name’s steelo.
    7 years ago
    Quoting steelo on 01 Mar 2019 11:06 PM
    You Lunatic!
  • Baloffski
    Baloffski
    7 years ago
    between Mrs. totally and Pauly Wrongco.
    I would seek professional help.
    Now, I have heard how a certain compound will revive your dent to pre existing damage.
    Not that expensive and does work, but get someone who has repaired similar. Should not be too exxy..
    7 years ago
    Quoting Baloffski on 02 Mar 2019 10:02 AM
    No more grog Mick! Go to bed. LOL
  • Baloffski
    Baloffski
    7 years ago
    Well, was the bloody second bottle of whiskey made me do it. Am but an armless dude, that rides motorcycles.
    Ohh , that would be the foirst bottle...
    7 years ago
    Jeez, sounds serious mate. I think you need a new bike!
  • Retroman
    7 years ago
    I had a long smooth dent in the left side of my 2006 Anniversary Dyna. Tank badge had taken all the grinding thankfully. ( happened in 2009 )
    Got 3 different Paintless dent removal guys out , not motorcycle specialist obviously.
    I stripped out the speedo console , fuel pump etc etc ( fuel injection bike obviously !)
    First 2 looked and/or tried and failed , said Harleys were too heavy gauge metal. They had done Jappers before no problem
    Third dude , "The Ding King" a Swiss guy based here in Perth WA , he got the ding out 95%+
    Long "spoons" levered against blocks of Jarrah on top of masking taped bath towels on the tank top surface.
    Dent came out like magic !!
    The new badge covered it 100% so happy days.
  • Baloffski
    Baloffski
    7 years ago
    Good tale Retro. Is there a way you can use liquid nitrogen or similar to remove dents? Just something someone mentioned.
  • Retroman
    7 years ago
    Problem apparently is damaging the paint on the way back to straight. In that case well what's the point I suppose.
    I have met other paintless repair guys since. Some have had success with Harley dings , fenders mostly , where you can work easily from behind the ding.
    Requires the fender off which can be a real labour intensive pain with the rear.
    HOWEVER most paintless operators put Harleys in the too hard basket.
    The liquid Nitrogen gig I have not seen personally ( except when the doc was freezing sun damage off my sorry heid !)
  • steelo
    steelo
    6 years ago
    Folks. Just came across this video on YT for paintless dent removal. Bloke did a nice job on the tailgate of a Toyota 4WD. Worth a look.
    Then I found this one for those of you with OCD
