Online: WideglidingNZ
Under mount LED indicators !
1/4
  • Ricca
    Ricca
    6 years ago
    On Behalf of Browns IND we are their WA dealers
    Perfect fit and AUS standard
    https://www.westcoastclothing.net/product/browns-ind-indicators
    Get your CNC machined blinkers fits genuine Harley controls from 1996-current
    WHILE STOCK LASTS!!
    *VROD
    *BREAKOUT
    *SOFTTAIL
    *DYNA
    *SPORTSTERS
    ___________________________________
    $199 Posted!
    6 years ago
    So are they ADR compliant?
  • Ricca
    Ricca
    6 years ago
    Quoting tussuck on 26 Feb 2019 08:33 PM
    Yes Sure are
    6 years ago
    Price $ ......?
  • noctm
    noctm
    6 years ago
    Quoting perthhog on 27 Feb 2019 05:16 AM
    Price $ ......?
    they're around $300 from what i can recall. maybe somewhere between $250-300
  • Far Canal
    Far Canal
    6 years ago
     $$ Ricca?
    6 years ago
    I do like the idea...nice and discrete.
  • potluk
    potluk
    6 years ago
    are they available in non led for bikes with globes up front or do they replace the globe ones. if so do they work properly without stuffing about with anything else electrical.
  • Ricca
    Ricca
    6 years ago
    Hey guys these are $199 Posted! anywhere in aus!
    we believe in true value and not rip people off!
  • Ricca
    Ricca
    6 years ago
    Price $ ......?
    Quoting noctm on 27 Feb 2019 07:06 AM
    $199 posted
  • Benno
    Benno
    6 years ago
    Quoting potluk on 27 Feb 2019 08:35 AM
    You’ll need a load equaliser, other wise they will flash erratically and you will get an alarm. I installed them and think they are great, but had to install an equaliser, was told they use such little power that the return signal is so similar to the outgoing that the ecm thinks they didn’t work, hence the alarm. Once the equaliser was installed, no alarm or erratic flashing.
    Edit: this happened to my 07 Dyna, it may be different on other models, just sharing my experience, I like the product.
  • Ricca
    Ricca
    6 years ago
    Quoting Benno on 27 Feb 2019 09:26 AMedited: 27 Feb 2019 09:53 AM
    Good point,
    Ive installed about 10 in the last 2 weeks and non have had any problems.
    Besides one 2007 night train needed the $35 part
    So this is all dependent how your bike reacts. for this price you cant go wrong!
  • Ricca
    Ricca
    6 years ago
    These are Led,
    Pretty much cut your current  wires and re solder these on! easy and a great product
  • noctm
    noctm
    6 years ago
    Price $ ......?
    Quoting Ricca on 27 Feb 2019 09:18 AM
    $199 posted
    cool, that's a bit cheaper than what i was seeing quoted to people via brown ind. on their facebook
  • Ricca
    Ricca
    6 years ago
    $199 posted
    Quoting noctm on 28 Feb 2019 02:41 AM
    $199 posted is what they sell for mate.
  • Mr.Mow
    Mr.Mow
    6 years ago
    Where are these ones made?
    6 years ago
    I am tempted as my old ones 'fell off' last month.
  • Ricca
    Ricca
    6 years ago
    Cant go wrong with these
    Warranty is giving if led or indicators become faulty within time.
    These have been giving to Heartland in USA aswell and they love them
  • Wholehog
    Wholehog
    6 years ago
    I’ve had on my 2013 fat bob for a while now...blinker flashes normal but the light on ya dash flashes fast....no biggie.Appart from that no issues .
  • steelo
    steelo
    6 years ago
    Doesn’t that indicate a blown bulb?
1/4
