DNA Mammoth wheels
  • Nath103
    Nath103
    7 years ago
    Anyone had first hand dealings with them, are they any good for the price?
    Other pros cons?
    Im looking at fitting a spoked set to my breakout and while they look good in pictures just want to be sure Im not throwing $$ down the toilet
    Nath
  • steelo
    steelo
    7 years ago
    I'm generally against big bike mods but they do look good.
  • Ricca
    Ricca
    7 years ago
    Nath they are fine you have a few options. if you want to save go to vpw  they are cheaper but still do the same job
  • Ratbob
    Ratbob
    7 years ago
    You’ve not mentioned what bike they’re going onto.
    Generally they add weight, big spokes = more steel = more weight, so they handle different by giving a greater gyroscopic affect and fall less easily into corners. No big deal but if you’re into handling and the twistie roads it’s something to consider.
  • STEAMER
    STEAMER
    7 years ago
    Quoting Ratbob on 19 Feb 2019 09:28 AM
    He says a Breakout in first post.
  • Ratbob
    Ratbob
    7 years ago
    Quoting STEAMER on 19 Feb 2019 08:07 PM
    Bugger damn, thanks Steamer so he did, betta get to Spec savers.
    Breakout rims are pretty light so moving to steel rims and fat spokes will add weight and affect handling in that the bike will want to stand up entering corners and be less cooperative through s bends etc. Guess it depends on how fast you like riding through the twisty bits.
  • Nath103
    Nath103
    7 years ago
    Thanks Gents for your input, I didnt think about the added weight. Cornering is pretty easy to throw it in at the moment and ideally Id like to maintain that.
    Ill maybe try and find a set of HD Turbines instead
    7 years ago
    Ha Ha hard to put Breakout and handling in the same sentence
  • Dan069
    Dan069
    7 years ago
    Quoting paulybronco on 19 Feb 2019 11:40 PMedited: 19 Feb 2019 11:42 PM
  • Dan069
    Dan069
    7 years ago
    Quoting Dan069 on 20 Feb 2019 07:03 AM
    Hi I have vpw fat spokes on my wideglide you won’t notice the weight only thing you have to run tubes they say tubeless but there not
  • Ratbob
    Ratbob
    7 years ago
    Quoting Dan069 on 20 Feb 2019 07:08 AM
    Yeah Dan the wideglide’s a good choice for fats, it suffers much much less and being a Dyna, albeit with that skinny front wheel, already handles way better than the breakout.
    Going from steel rims to steel rims, you’ve only upped the spoke diameter/weight.
    The breakout runs an alloy 240 rear vs your steel 180 and an alloy 130 front vs the WG’s steel 90. As you mentioned, plus the tubes and it sure adds up to a difference you can feel.
    Have you posted any pics of your WG, would like to see it.
  • Ratbob
    Ratbob
    7 years ago
    Yeah Pauly, guess it’s one of the latest oxymorons.
    7 years ago
    Quoting Ratbob on 20 Feb 2019 08:40 AM
    Very true !
  • Nath103
    Nath103
    7 years ago
    I honestly have no issues with the breakouts handling
  • Ratbob
    Ratbob
    7 years ago
    Quoting Nath103 on 20 Feb 2019 08:23 PM
    That’s good Nath.
    It’s an objective thing, depends what you’ve been riding and where. Here in the Adelaide hills, Street Glide wins over Breakout that wins over M8 Fatboy etc.
    I reckon the new Fatboy now holds the worst handling crown, it’s probably those big/solid/heavy wheels.
  • STROPP
    STROPP
    7 years ago
    I’ve got them on my slim, makes fuck all difference  to handling, I bought them as vpw don’t do the ones I wanted.
  • Ratbob
    Ratbob
    7 years ago
    Quoting STROPP on 21 Feb 2019 01:59 PM
    Yeah Stropp, the Slims probably the perfect bike for fat spokes cause you’re not adding any significant weight to the already beefy wheels. So negligible if any handling change. Got a pic of the whole bike for us?
  • STROPP
    STROPP
    6 years ago
    Quoting Ratbob on 21 Feb 2019 10:30 PMedited: 21 Feb 2019 10:31 PM
    Sorry mate took my time ??
  • Ratbob
    Ratbob
    6 years ago
    Quoting STROPP on 16 Jun 2019 09:53 AM
    Man that’s nice Stropp, loving the top end and exhausts, the whole thing just looks right. Cheers
  • Chaser
    Chaser
    6 years ago
    I just put DNA Fat 40's on my Deluxe from Easy R in Brisbane.  Love them!
