Online: beaglebasher
Key fob has new batteries. Bike wants PIN after each stop/start
  • xthommox
    xthommox
    7 years ago
    2013 Fatboy.
    Hi, tried to start the bike. It's been on trickle charge for months. Wants PIN. Put in PIN. Starts. Turn it off. Try to start again. Wants PIN. Aaarrgghh! Called Harley. Changed your fob battery? Nope. Bought 2 brand newies. Installed it. Same issue. Watched youtube vids so am doing it correctly (the bike starts, so I am). Has the FOB died as the bike is not recognising it? Is there a check/test for it to see if it is working?
    Ideas? Thoughts?
  • steelo
    steelo
    7 years ago
    Saw on another forum to check the fob battery is inserted the right way.
  • xthommox
    xthommox
    7 years ago
    Hi, yep battery is facing the correct way. I'll look into the 9v thing. Cheers.
  • gidgi
    gidgi
    7 years ago
    try removing main fuse wait a couple then replace I sort of remember reading this B4 some where.it re sets everything
  • WideglidingNZ
    WideglidingNZ
    7 years ago
    There is definitely a 9 volt rechargeable battery there,  I found that out when I removed my main battery as alarm went off for about half an hour
