Headlight shell removal
noddy59
7 years ago
Hi all , I know I probably wont like the answer to this one but is there a way to change out the headlight shell on my old fxb without removing half the wiring harness or cutting wires (could be a bitch cause I'm colour blind) .
just checked the wiring diagrams and all the main terminal block connectors are in the headlight shell, got the speedo off and tank dash there doesn't appear to be any plugs to split the wiring harness .
any advice Please . I really really don't want t cut anything if its not necessary.
Thanks .
Stewy
7 years ago
did one not long ago..
cunt of a job..
remove the wires from the plugs using a paper clip or small screwdriver.
draw a map or take a pic as you go
noddy59
7 years ago
Thanks Stewy ,watched youtube, made my own tools, took a shitload pic's and a heap of drawings and notes, now I just got to put it back together.
