Online:
WideglidingNZ
2 man tent
2 man tent
Odin
7 years ago
OK boys.
what brand 2 man tents would you recommend for camping. Have never camped before so I have know idea about any of this stuff. please be kind
I have a Streetglide so have bags to carry stuff, and a luggage rack
Odin
Ken in Cairns
7 years ago
I use a small hiking style tent. Very light and small when packed up.
Not a huge tent, but ok for one.
Mannagum Howque Hike-Lite 2 person Hiking tent. Got mine from Wild Earth for $189.
Cheers Ken
dyna13
7 years ago
Coleman ridgeline 3 person, super light weight but strong tent. Packs up to stuff all. I’ve had 2 man tents but found them to small length wise. The cook and I sleep on a blowup mattress and it leaves I little room inside for your shit that’s out of sight.
Around $160
DESCRIPTION
Let new adventures begin with the Coleman Ridgeline 3 Person Hiking Tent! Compact and lightweight, the Coleman Ridgeline is ideal for hiking or backpacking. Included is an ultra-fine mesh inner, for use as a screen tent in those warmer climates. The tent is a breeze to set up, thanks to the 2 pole tunnel construction with lightweight aluminium poles, V stakes and four heavy duty Q/R buckle attachment points. When the weather takes a turn, Coleman have you covered, with a heavy duty bathtub floor, 2000mm water rating and 100 km/h wind rating! Explore the outdoors with the Coleman Ridgeline 3 Person Hiking Tent!
FEATURES
Compact and lightweight tent for hiking and backpacking.
190T seam sealed polyester, PU 2000mm water rated fly
Heavy duty 190T polyester bathtub floor
Easy to set up featuring lightweight aluminium poles
Ultra fine mesh inner for use as a screen tent in warmer climates
Wind tested to 100kph
100 x 240 x 175cm
Packed dimensions - L42 x W19 x H18cm
Weight - 2.53kg
Oz Dan
7 years ago
I just use a swag (waterproof) and carry a trangia cooker....... I often go camping with this setup on my King, easy to carry and it’s all I need.
