Online: beaglebasher
Stalling, bad idle, hard restart.
  • petebob
    petebob
    7 years ago
    Hi all
    After some ideas on a very intermittent problem we have with my wife's 2013 Slim.
    Problem started 18 months ago for no real apparent reason. Bike would start idling either fast (up to 1700rpm) or low to to point of stalling. Usually it would idle fast when downshifting and stopping at lights, then it would switch to very low idle and stall. Misfiring and carrying on. If we were on a ride and stopped for a 45min drinks break it would not restart without cranking the throttle wide open. Plumes of black smoke would billow. Next few times riding there would not be the slightest issue. Then the problem would pop up again. Took it to our mechanic who is an independent HD trained tech, with an outstanding reputation here on the Coast. He checked fuel tank internals and changed the filter. Checked for inlet manifold air leak, found one so replaced all seals. Cleaned IAC. Bike ran fine for a month, then started the same b.s..
    Replaced IAC. No difference. I should mention that there were no DTC's thrown. Went through the process and changed out all inlet sensors as well as CPS. After this, bike ran good for almost a year. I should also mention that this is so intermittent, we've left it with him for a couple of weeks, where he's ridden it every day and it hasn't faulted!
    Anyway, we had it in his shop for 5 weeks recently to have the front end powdercoated. Maree picked it up after completion, got 2km down the road and the fuckin thing started doing it's farting stalling thing again. GOT IT restarted, straight back to the workshop, running like a dream. Hooked up to the SERT. Nothing out of the ordinary.. rode home,  no further issues. Fast forward a couple of weeks, just doin a short local loop up a tight hilly road (1st and 2nd gear) starts fumbling a bit. Across the top then back into traffic in town. Thru a set of lights, missing, coughing and dies all together. On the ph, the tech comes out. This time it's thrown a code for ETS fault. We restart it after maybe 30mins with no probs. Back to the workshop and sensor replaced. All good we think. Have done maybe 400km since then with no probs. GOT out today rode for 25km at 80kph all good. Slow dow/stop for lights - idling at 1700rpm. Fuck. Next set of lights same deal. Next set running ok. Next set, wants to idle slow, bout 750rpm. Stop for fuel, a bit hesitant to restart. Carry on a bit further and end up in gridlock traffic. Stop n go shit. Bike missing farting etc. Dies all together. Restart by cranking throttle wide open. Get out of the traffic and on to the highway all ok. Get off to head for home thru a couple of T intersections. Missing wanting to die. Have to keep the revs up to keep it running. Get home, again after 15-20km of 80kph, bikes running perfect. I took it for a 30min run and tried to replicate all the shit we'd just been thru and it didnt miss a fucking beat! Anyone got any ideas? The only sensor that hasn't been changed (I think) is the VSS, but there have been none of the other symptoms that go along with this, e.g.  Speedo fluctuations, turn signals not cancelling.
    I'm sorry this is so long and drawn out, but it's got us fucked.
    Help anyone??
  • petebob
    petebob
    7 years ago
    Yeah, thanks mate. I'm leaning towards something electrical causing over-fuelling. Sensor, dry connection, ecm. I dunno. If it dies, the only way it'll restart is cranking with throttle WFO. LOTS of black smoke (unburnt fuel). When it burps and farts on downshift, also puffs of black smoke.  We haven't really investigated the ignition side of things, but a failing coil pack etc would surely throw a code?
  • robots
    robots
    7 years ago
     Hi Petebob,
    I chased a fault on mine for a long time, idle related.
    All sensors checked out well, i think they are fairly reliable, same stuff for automobile world.
    You have to check all wires are working, no shorting, wires that have to bend to get to sensor or fuel injectors
    But I believe the intake manifold seals are the cause of a lot of these issues, stick with HD ones, make sure clamps are on correct way, make sure air cleaner backing plate is on when you position and tighten throttle body down, use Vaseline
    7 years ago
    Have a look at the temp sender at the rear of the front cyl on the left side of the bike. Make sure its tight if it is the sender may be faulty. It was on my 2012 street glide and i replaced it
  • petebob
    petebob
    7 years ago
    Quoting paulybronco on 05 Jan 2019 11:57 AMedited: 05 Jan 2019 11:58 AM
    Thanks PB. This was the sensor that threw the fault code. Replaced. Bryan and Dane have spent hours on this thing, with no definite solution. No fault of theirs. Couldn't have asked for more back up.
    Cheers Robots. Manifold seals replaced and rechecked.
    It's getting to the stage of replacing looms or ecm and seeing what happens. Bloody costly business. Because the fault is so intermittent, it's almost impossible to track down. I even had the idea of leaving the SEPRT plugged in and recording continuously, so that it would just over-write until the problems started, then we could stop recording and review. Used to be it would record for 1 1/2 hrs then just keep overwriting data until stopped. Now it will only record for 15mins and does not overwrite. Thanks EPA.
    Maree has lost all faith in the bike and now doesn't trust it. Can't say I blame her.
    7 years ago
    Quoting petebob on 05 Jan 2019 12:23 PM
    Umm here's a last leftfield shot. Brian Farrow (your tech) was with Sunny coast Harley when i had some similar symptoms with my 2012 street glide, not all the same but very similar. Brian spent a long long time on it and eventually tracked down to a pin in the wiring loom  that goes into the injectors. Straight after mine they had a few go thru with the same problem. He is a great tech.
  • petebob
    petebob
    7 years ago
    Thanks Paul. I'll mention it to him when we go in tomorrow.
  • robots
    robots
    7 years ago
    as you mention just about all sensors changed and no fix to the problem.
    need the wiring diagram in the manual. follow it through with multimeter as VirtualT advised. Probably have to lift tank or remove throttle body to get good access.
    this takes time, I would do at home. Need to write everything on paper.
    no point changing ecm or main wiring loom if no fault is found. If fault is found to lets say IAC harness then a new wire could be put in from IAC to ECM
    if high kms i would change throttle body clamps also, could be warped. Not a lot of mechanics want to install the throttle body with air cleaner backing plate attached to it as not much room to install and tighten bolts, but its the only way to "center" throttle body otherwise air cleaner backing plate will move it when installed.
  • robots
    robots
    7 years ago
    be interesting to see how good they are, not sure how they could spend hours on it if they changed a few sensors
    no check engine light when riding, so sensors and wiring are operating as the ECM getting signals all the time
    7 years ago
    Quoting robots on 06 Jan 2019 11:23 PM
    I will vouch for Brian he is a very good tech, don't recall if he was a master tech with HD or not
  • petebob
    petebob
    7 years ago
    They're all top rate techs there.   Weve used him for a couple of years now, and his offsider, Dane did a lot of work on this bike when he was at the dealership. The hrs spent that I mentioned involved a hell of a lot more than just swapping out a few sensors. Wiring checks, connector pins, manifold removal and much more. Put a new battery in it today, as the old one was getting a bit tired, and will probably end up changing VSS. We just have to keep trying different stuff.
    Been plenty of instances of sensors failing with no fault code.
  • robnicko
    robnicko
    7 years ago
    Petebob,
    you mentioned a new battery being put in today. did you ever have the old one load tested etc?
    reading through your initial post it seems to be more apparent in instances where the bike gets hotter, eg traffic, intersections etc
    im wondering if the battery is possibly boiling internally. Does it show any visible signs of bulging or leaks?
    Also, check the charge rate when idling, should be abound 14.3 just after startup
    just a thought
    rob
  • robots
    robots
    7 years ago
    I could ride on cold days and wouldn't get any issue with the idle, could even do good 3-4hr country roads
    then presto when you get back into town, roundabouts, intersections up goes the idle
    check your wiring first using the service manual
  • robots
    robots
    7 years ago
  • Soapbox2627
    Soapbox2627
    7 years ago
    what if
    could there be a bit of cloth or sponge in your tank as you are weaving about it covers the outlet letting minimal fuel through, turn the other way the fuel moves it off, say when you turn left is the worst
    the only starts with full throttle could be it is settled on the outlet on the side stand (left),
    your sensors will be reading the engine needs more fuel and open up for more (high Idle), then the ECU will tell it there is to much fuel and the low Idle/stall
    the cloth/sponge would not make any sound when tank was taken off and the tap checked or shaken and could get stuck to the side of the tank out of view on a visual inspection
    just a thought, one of two things can happen, you find something in there or I have wasted an hour of your time
  • petebob
    petebob
    7 years ago
    Thanks for the replies and ideas guys. I've been at sea for 11 days. Home for a few hrs today then back out for another stint. Maree hasn't had her bike out while I've been away, so no updates. I know she's riding next weekend, so might find out more then. Old battery was tested a couple of months ago, read on the low side of good. I'm hoping that's the problem. I will update as I can.
    Cheers Pete.
  • petebob
    petebob
    7 years ago
    Bit of an update....new battery fitted.
    1100km run to Monto and back a couple of weekends ago, 500km this weekend and no problems at any stage. Fingers crossed. Maybe a faulty battery cell breaking down under certain conditions?? I hope that's it anyway.
  • Nutty
    Nutty
    7 years ago
    I hope the battery fixes it Petebob!
    I would throw a fresh set of injectors at it if it happens again. The fact that it clears on open roads and loads up at idle/town running and blows black smoke suggest a weeping injector. The injector circuit is obviously firing OK to flood the motor. Just a thought and something that can be removed from the list...
  • petebob
    petebob
    7 years ago
    Cheers Nutty,
    Will keep that in mind
