Online:
Soapbox2627
V Rod 2017 Mirror Replacement with Led Wiring problem
interacts
7 years ago
Hi everybody I need some help on wiring Axe mirrors on my 2017 V Rod Muscle.
Standard wires on V Rod are Left Hand Black with White stripe wire and Purple wire ... Right Hand Side Brown wire and Black wire.
Mirrors have 3 wire red black and yellow .
Black earth
Red park lights which i wont use.
yellow indicators
I connected as their wiring diagram black to black and yellow to purple but nothing works.
tested new lights on battery they work.
I rang 2 Harley shops one told me to reverse wires as they were LED and are sometimes opposite and the other shop said there should be 3 wires on the Harley I think he was a bit lost.
Can any body help me on the correct way to wire these in.
