petrol stain on tank
  • micathia
    micathia
    7 years ago
    I use my bike for commute and weekend. So I have to add petrol at least four times a week, sometimes 8 times. From time to time the petrol dripped on the fuel tank.
    Now it looks ugly. I tried to use soap water to clean them, no luck. After the rain, the tank shows hundreds of round dots of seven rainbow colours.
    How can I clean them up? The bike is matt black.
    Does dealer have a special product to deal with this?
    thx
  • steelo
    steelo
    7 years ago
    Have a look at this thread on another forum M
    May help, but may also leave you a bit in despair
  • Far Canal
    Far Canal
    7 years ago
    Quoting micathia on 19 Dec 2018 08:50 AM
    thx
    Got any pictures of the hundreds of round dots of seven rainbow colours.?
    Spilt the odd splash of fuel on my tank and all I get is gladiators on horesback charging at me with murderous intent.
  • Daffy
    Daffy
    7 years ago
    thx
    Try paint doctor. It's a polish.
    7 years ago
    Its going to be a staining or discolour in the clearcoat, so a good quality paint correction product with a DA polisher should take care of that easy.
    The key is 'good quality' and the right product for the job.  (the tools alone can cost $300+ and then another $200 for the products and pads, but its a good investment as you can reuse for your car etc)  Are you in Melbourne East or West?
  • micathia
    micathia
    7 years ago
    thx for all reply. I guess commute bike should look like commute bike then.
  • Soapbox2627
    Soapbox2627
    7 years ago
    how far do you commute to have til fill up that often, would be cheaper to buy a house closer to work
  • B0GN
    B0GN
    7 years ago
    Quote source removed.
    Bahahahaha. Fuck that made me laugh :-)
    Ol mate could have a peanut tank? I dude at work says he gets to work and back then has to fill up.
  • micathia
    micathia
    7 years ago
    Giving the content of the comment here, I think you fall better under the definition of "clown".
    PS, but thAnk you for the suggestion. Demin Cleaner, can't believe Harley has that HARLEY-DAVIDSON DENIM PAINT CLEANER WITH TRIGGER SPRAY - 16OZ 93600078.
  • micathia
    micathia
    7 years ago
    Quoting Soapbox2627 on 20 Dec 2018 06:27 AM
    I have 6 different work locations every week.
    But no, those locations are not the best place for investment.
    7 years ago
    Invest in a good sealing gas cap too and stop dribbling.  I fill up twice a week and paint is better looking than when it left the factory.
    7 years ago
    Its Xmas...we love everyone!
    Try a Ceramic coat on the tank like CQ Quartz UK, as that may actually provide a good barrier.  Ploishes and waxes will just run off - in fatc some of the yellowing could be the petrol reacting to whatever wax you use.
    7 years ago
    I never really count the number of times I fill up in one week ( but I ride my sporty a lot ) it is white too, I could have got fuel on the paint a few times, but I'm mostly careful. & if I do spill some I wash off with water before riding off. 15 year old bike ( 16 next week ) can't see fuel stain's. I always thought the new paint they use was fuel proof? I can remember old days fuel stuffed paint if not cleaned off quick.
    also today's Harley's fuel caps seal even if bike upside down. ( I have tested that out at drags, put my 01 twin cam dyna down at 180kph, I went down the track on my butt & clocked a good speed on my own, the bike went down the track on it's handle bars ( sparks ) not one drop of fuel lost. I got straight up myself.
  • Wideglider
    Wideglider
    7 years ago
    Good bit if info there Krash - I'll have piece of mind my fuel tank won't get stained with petrol next time my bike is upside-down!
