WM8-22x Cams
WM8-22x Cams
Jasbel
7 years ago
Hi
I currently own a 2018 Harley Heritage Classic and looking at a cam upgrade, one cam I do like is the WM8-22x cam and was wondering if anyone sells the Woods Cams here in Australia if not I may look at other alternative like rpt he SE 447 Torque Cam
Has anyone had good results and experiences with the SE 447 Torque Cams
7 years ago
I don't think anyone here stocks Wood Cams.
Try
https://www.fuelmotousa.com/
in the US
Excellent service usually .
7 years ago
Quoting Jasbel on 13 Dec 2018 08:08 AM
Hi
Think loftybob had that cam in his road king
7 years ago
Hi
I can't say on the SE cam or the Woods cam , but Bobby Woods gets Andrews to make his cam's.
Red Shift make a good cam for them too. but if I had a M8 and was stock & I wanted more of everything, I would just have a set of the SE CNC heads fitted and get a good tune , custom Map on a Dyno with load control & AFR with a experienced operator that can tune. it would take all day could cost you from $600 to $1k, but well worth it. as the CNC heads a different casting ports look better and I think you would get more low end Torque from them & stock cam. the heads are very important along with the tune.
