Online: Soapbox2627
Wondering who has buzzing front brakes and who has silent front brakes?
  • Smokey61
    Smokey61
    7 years ago
    Is it 90% or 10% either way?
    7 years ago
    Silent until I overdo it and then screeching tyre sounds
  • steelo
    steelo
    7 years ago
    2003 Soft tail deuce - single front rotor - silent
    2014 Ultra - double front rotors - no noise but annoying vibration - rotors seemed buckled
    2017 Ultra - double front rotors - silent
  • Ratbob
    Ratbob
    7 years ago
    2009 CVO Fatbob, so twin disc, drilled, no noise.
    7 years ago
    2012 street glide Lyndall race pads.....buzzes like hell when you grab a fist full
  • WideglidingNZ
    WideglidingNZ
    7 years ago
    My 2015 wideglide is a buzzy bee also
  • Geoff3DMN
    Geoff3DMN
    7 years ago
    My 2012 Dyna (single disk) was a buzzer under brakes, my 2017 Street Glide (twin disk) is not.
    7 years ago
    Rollies in Brisbane are the importers/distributor. Great pad but if the buzz annoys you maybe stay away from them
  • Smokey61
    Smokey61
    7 years ago
    There's been some references to sintered pads, I'll try the non-sintered pads first. Local dealer carries Lyndall pads. If the cicada is still there, I'll try other brands.
    7 years ago
    Quoting Smokey61 on 05 Dec 2018 09:35 AM
    It was me that mentioned the sintered pads......i use Lyndall pads and they do make the noise, these are the current pads in my bike
  • Ratbob
    Ratbob
    7 years ago
    Can someone tell me why the braking noise matters ?
  • Smokey61
    Smokey61
    7 years ago
    Quoting Ratbob on 05 Dec 2018 11:29 AM
    Because it's fucking annoying.
  • petebob
    petebob
    7 years ago
    As I wrote in the other thread...
    08 Streetbob - HD pads, Lyndell pads, plus another brand I can't remember the name of. The cicadas have been buzzin since day one. Doesn't bother me.
  • brash
    brash
    7 years ago
    17 Low Rider S - Buzzes like there is a wasp in my reservoir.
  • Smokey61
    Smokey61
    7 years ago
    Thanks for the replies so far, a small sample shows buzzing brakes are common, but not universal. That's useful information.
    7 years ago
    Quoting Smokey61 on 05 Dec 2018 09:19 PM
    For me the noise is there under most application of brakes but grab a fistfull from higher speeds and you really hear it
  • Muzza Wa
    Muzza Wa
    7 years ago
    Silent on both my 2012 & 2016 Fatboy Lo ‘s
  • Adz69
    Adz69
    7 years ago
    No front brake noise on my 1997 FXDWG.
