Online: B0nes
I cant find Neutral
  • The PM
    The PM
    7 years ago
    Hi I have just bought a HD Fat Boy 2018 8 months old and It is near on impossible to find neutral when stationary. Any clues anyone? It seems if I slow up quickly to a near stop it is impossible but when travelling slowly and coasting I can find neutral 90% of the time. Help!
    7 years ago
    Quoting The PM on 02 Dec 2018 08:34 PM
    It’s under warranty so take it back to dealer for adjustment
    7 years ago
    Dealer!   Sounds like a simple clutch adjustment if it shifts in okay when your coasting to a stop.  Do you know the service history or mods done to the bike?
  • The PM
    The PM
    7 years ago
    Quoting fatbat on 02 Dec 2018 08:44 PM
    Thanks for that, I already have once but not sure if they get it, saying it is relatively normal.
    7 years ago
    Quoting The PM on 02 Dec 2018 11:46 PM
    It does not take much clutch drag to really bugger up finding neutral.
  • The PM
    The PM
    7 years ago
    Quoting tussuck on 02 Dec 2018 11:43 PM
    I spoke to the previous owner last night she had the same issues but did nothing about it. Stock standard 2018 Fat Boy. My fear is that if the clutch plates have been overheated they now may be buckled.
  • Hound_Dog
    Hound_Dog
    7 years ago
    Relatively normal? LOL dealer speak for couldn't be fucked.
    7 years ago
    Quoting Hound_Dog on 02 Dec 2018 11:54 PM
    Agree.... that is NOT normal.  Back to the dealer and tell them to get it right this time.
    7 years ago
    Quoting The PM on 02 Dec 2018 11:53 PM
    Stop panicking the plates will be fine. The boys are correct its a simple clutch adjustment.....are you going to wk on the bike yourself? If so now is an easy fix to adjust the clutch otherwise you will be charged by the dealer for a simple adjustment
    7 years ago
    Quoting paulybronco on 03 Dec 2018 01:02 AM
    Damn, how can we instill a sense of extreme panic in the man if your going to chip in and tell the truth!
    I recon get a service manual and then spend 10 mins doing the job himself as its one of the easier maint tasks on a Harley.
  • The PM
    The PM
    7 years ago
    Quoting tussuck on 03 Dec 2018 04:30 AM
    Yes thanks again. I took the bike back today and spoke to the 2 ic who had another go and it is worse. Now what they will do is pull the clutch apart next week to see what the story is. No skin off their nose as the factory is paying I presume. Ill keep you posted
    7 years ago
    Cool, I'm keen to see what the issue is.  At least they are pulling it apart!
    7 years ago
    This is a hydraulic clutch now isn't it?
  • The PM
    The PM
    7 years ago
    Quoting paulybronco on 03 Dec 2018 07:29 AM
    no cable
    7 years ago
    Quoting The PM on 03 Dec 2018 07:30 AM
    no cable
    Cool, my money is on adjustment
  • The PM
    The PM
    7 years ago
    no cable
    Quoting paulybronco on 03 Dec 2018 07:36 AM
    they have had 2 goes at it, cant be that hard surely. Anyway they are going to pull it down and have a look.
    7 years ago
    no cable
    Quoting The PM on 03 Dec 2018 07:45 AM
    Well by simply adjusting the cable they may not have nailed it , they need to take the derby cover off and adjust the clutch internally
    7 years ago
    Just read this post, is the clutch pull very light? or is it a heavy pull?
  • The PM
    The PM
    7 years ago
    Quoting Krash Kinkade on 03 Dec 2018 10:40 PM
    no not particularly tight, fairly normal
