Online:
beaglebasher, Stuart
fat bob exhaust on a slim?
me_ashman
7 years ago
Hi, can't find much out there if fatbob pipes would fit on my slim. I know it will need brackets made, would the rest bolt up fine without clearance issues?
Ratbob
7 years ago
I reckon you’ll be the first to try. Might depend on the year, don’t the new Slims have a 240 rear ?
me_ashman
7 years ago
Not sure about the new ones, mine is '16 model with 140 tyre
Fey
7 years ago
Why a FB exhaust?
GTEEZ
7 years ago
I reckon it would. I put a '10 Wideglide V&H system (180? tyre) on my "18 Breakout (with 140 tyre). Mainly because nothing was available at the time. Cut, weld and grind a little. All good.
me_ashman
7 years ago
Quoting Fey on 26 Nov 2018 08:04 AM
Why a FB exhaust?
Dunno, like to try different ideas
