Online:
Retroman, B0nes
front springs
front springs
weasel 76
7 years ago
ive just brought some progressive springs p/n 11-1525 for my 2016 wide glide and the HD manual says 95mm from oil to top of fork and progressive says 140mm has anyone fitted these and any tips thanks
Ken in Cairns
7 years ago
Following the progressive oil level recomendations I believe is correct. Did they supply yhe oil or supply an approved oil list and viscosity?
You could check with either progressive or the supplier of the springs.
Good luck.
Cheers Ken
Drac
7 years ago
https://www.wwag.com/cgi-bin/WebObjects/WebSite.woa/wa/DirectAction?action=forceEnglish&page=TechTipsCapFork
Try this
Or go to www.wwag.com and click service and tech tips for capacities
