Online: John.R
Harley Davidson Street 750 and Street 500 | Odeta Stuikys Rose
  • odetastuikysrose
    odetastuikysrose
    7 years ago
    Hello members
    This is odeta stuikys rose
    I am planning to buy Harley Davidson Street bike, but I am bit confuse between Street 750 and Street 500.
    Can anyone give me some advice, which one will be better Street 750 or Street 500?
    Thank you
  • Benno
    Benno
    7 years ago
    Neither
    7 years ago
    LOL
  • Ratbob
    Ratbob
    7 years ago
    Hey Rose, don’t mind the boys sense of humour. (Good though)
    There may not be many members with either bikes. I haven’t riden them but from the little I know they are identical except for the larger displacement (engine size) achieved by a larger bore.
    So if they are the same frame etc, I’d go for the larger engine.
    You may not use the extra power all the time but, if you start with the smaller engine and find you want more, you’ll need to change bikes. If you buy the larger engine, 750, you’ll always have extra power when you need it and usually, as you get used to your bike, you will want more power because it’s more fun.
    Also, I reckon the 750 will have a greater resale value.
    Happy hunting and enjoy your new ride.
  • Arron
    Arron
    7 years ago
    About the only reason you would choose the 500 would be if you needed a LAMS approved bike.
    7 years ago
    Quoting Arron on 15 Nov 2018 10:30 AM
    Good point
  • odetastuikysrose
    odetastuikysrose
    7 years ago
    Quoting Ratbob on 15 Nov 2018 10:12 AM
    Thanks Ratbob
    7 years ago
    odeta , as I have never had a chance to ride the 750 or the 500 HD's. I would say take both for a long test ride, both in heavy traffic & on an expressway & also in twisties. Just so you know how they will feel in all the conditions you might have to ride them in.
    you might find the 750 has a heavier clutch pull, but no way of knowing till you ride one.
    good luck & post up your test ride experience.
  • odetastuikysrose
    odetastuikysrose
    7 years ago
    Quoting Krash Kinkade on 16 Nov 2018 09:44 PM
    Thanks for suggestion Krash Kinkade
    I will definitely post my ride experience.
  • JFE
    JFE
    7 years ago
    Go the 750 - I found the engine to be much more enjoyable to use, especially if you swap out the pipe for a louder one. But as advised, ride both and go with what you like the most.
  • Far Canal
    Far Canal
    7 years ago
    Only meant to post this thing in "Motorcycles Other".   Not the 750 and 500 thread. My mistake.
  • Ratbob
    Ratbob
    7 years ago
    Quoting Far Canal on 22 Nov 2018 07:35 AMedited: 22 Nov 2018 07:59 AM
    What a ripper, frame’s probably no worse than the original. Those XS Yams had more wobbles than a belly dancer.
  • stout
    stout
    7 years ago
    Hello Odeta Stuikys Rose,
    You can buy any both are good.
  • Amberwhiskey
    Amberwhiskey
    7 years ago
    My wife recently bought the 500, she still has P plates so needed a LAMS approved bike.
    The other reason is the 500 has a much lower seat height & even with this she needed shorter shocks & the reach seat.
    The 750 was a very poor seller, superseded 2017-18 models are available much cheaper than the 500.  Bargain hard at the
    dealer, they want to shift them as a new model is coming out.
    They have twin front discs & better suspension, look better & go better.
    If you fit on a 750 & are licenced to ride one there is no choice really.  The 750 we get in Australia is the faster Street Rod.
