Online: Retroman, B0nes
brand bew cvo problem not happy
  • goingmad1
    goingmad1
    7 years ago
    hey  guys  could use some advice  atm I just bought a brand new 2019 cvo streetglide  needless to say it cost me a bomb  ok had it 4 days took it out for  a run   and shit hit the fan
     on my way home the bike got very hot  as I turned into my street the bike went into shut down mode now power etc   I got it into my shed turn it of all I could smell was oil and its was bloody hot as  check the engine oil  it was very low  in saying that  the oil lvl was fine when I picked the bike up   ok  next step sent it back to the shop  broadmedow frasers   to me the bike seemed like it cooked itself oil pump problem perhaps no idea at this stage  wtf do I do now and what should I exspect from the dealers cheers and advice  would be apreciated
  • DocGreen
    DocGreen
    7 years ago
    Quoting goingmad1 on 12 Nov 2018 10:01 PMedited: 12 Nov 2018 06:10 PM
    fark, that's no good mate - unfortunately google "Milwaukee 8 sumping", there is a pretty good post on the US HDForums.
    You have to let the dealership handle it thru warranty, hopefully you get a good resolution - keep us posted.
     HD have recently released a new pump plate with a seal which reportedly fixes the sumping issues - depending on when yours was built, it may not have this fitted.
    DocGreen
  • Baloffski
    Baloffski
    7 years ago
    Shit that"s a bugga. Hit on the dealer for fix asap.Not happy Jan..
    7 years ago
    I would ask for a new bike....  or make damn sure the entire engine etc is 100% replaced.
    They could mess around for months as well....so make sure you ride them tho get a FAST resolution.
  • Ratbob
    Ratbob
    7 years ago
    Fuck ain’t the word for it.
    Can ask for a new bike but that isn’t what warranties are for. I believe a guy here in Adelaide’s on his third engine but haven’t got an update on how it’s going. One good thing was they gave him a like bike during the repairs.
    Though as yours is a CVO that might be difficult but try to accept nothing less. Hopefully it will be sorted quickly.
    Keep us posted.
  • goingmad1
    goingmad1
    7 years ago
    its  all good guys  I was told Harley is going to send a  brand new 1 over  with matching numbers they  said there was a problem  with the 17  and 18 cvo  and also a few of the early 19 models  but now have fixed the problem being the oil pump  been told they have copied the ss design  iam going to get a new phase 6 engine  also Newcastle frasers have said they will give me a ride in the mean time  thanks to them cheers all
  • Wideglider
    Wideglider
    7 years ago
    Sounds like a good outcome with dealers behaving themselves.
    7 years ago
    good result!
  • Humbug
    Humbug
    7 years ago
    Thats a great result.
  • TJU
    TJU
    7 years ago
    Great news there goingmad ... can i just ask when you say you are getting a phase 6 engine do you mean you are getting the 6th engine that has been updated since the M8`s have come out or a Stage 6 engine .
    Only ask as i have a full Stage 4 Screaming Eagle 2017 Road Glide Special and have read where guys are getting Stage 5 or bigger engines and i just wasn`t aware you could go bigger than a Stage 4 .
    When my motor was done they upgraded the Oil pump and haven`t had any issues as yet ... fingers crossed ... well except this newest recall affecting the Clutch ... mine is on the list but Harley Australia have not got enough repair kits to go around as yet  ... or so Gasoline tell me ... 280,000 worldwide so the experts say .
    You might want to get them to check yours as well while it is in being fixed for other issues .
  • Ratbob
    Ratbob
    7 years ago
    Great news, ain’t restored my faith in HD but it hasn’t hurt it.
  • Daggs
    Daggs
    7 years ago
    Good result mate but yeah, what is this phase 6 engine you speak of?
  • goingmad1
    goingmad1
    7 years ago
    Quoting TJU on 14 Nov 2018 12:10 AM
    ok no what iam saying is the 1st 117 built  lets say was a phase 1 then they improve on that engime as time goes  on  now they are on the phase 6 design pretty much just as time goes on small faults  are fixed or improved :)
  • Ratbob
    Ratbob
    7 years ago
    Thanks Goingmad. I’m amazed how many iterations our bikes and cars go through. Buying Prado parts I used to wonder why they needed the exact VIN number for simple bits, turns out there were many versions of the 120 over its 4yr production life.
    When your new bike arrives and all’s good, you gonna change your logon?
  • Ken in Cairns
    Ken in Cairns
    7 years ago
    Perhaps calling each newer model of the M8 a Mark one, Mark two etc for the newer versions as they progressed through the improvments would be better than using the term phase one etc.
    Like they did fot the Cortina, Spitfire, Mustang etc.
     Just an idea.
    Cheers Ken
