Online: B0nes
Mainshaft Bearing Removal
  • rodrocket
    rodrocket
    7 years ago
    Greetings all
    Does anyone here in Melbourne have the tool for removal & replacement of the outer mainshaft bearing that we can borrow or hire
    need to replace the bearing on a 2006 FXD 88Ci
  • robots
    robots
    7 years ago
    which tool is that rodrocket
  • rodrocket
    rodrocket
    7 years ago
    MAINSHAFT BEARING INNER RACE
    PART NUMBER TOOL NAME
    REMOVER/INSTALLER
    HD-34902-C
    Removal
    NOTE
    Bearing outer race installation requires properly aligned bearing
    inner race. Use the recommended tool MAINSHAFT BEARING
    INNER RACE REMOVER/INSTALLER (Part No. HD-34902-
    C).
    1. See Figure 5-22. Install end cap (2) into end of mainshaft.
    2. Position puller (3) around mainshaft, under bearing inner
    race.
    3. Turn forcing screw (4) clockwise while holding puller to
    remove bearing.
    2 1
    sm05961
    1. Bearing inner race
    2. End cap
    3. Puller
    4. Forcing screw
    Figure 5-22. Pulling Mainshaft Inner Bearing Race
    Above is from my breakout service manual
    just googled the tool part number and came up with this kit
    My son threw the belt on his bike and now he has it in bits he noticed the outer bearing is trashed....
  • robots
    robots
    7 years ago
    Okay good
  • robots
    robots
    7 years ago
    Will check mine. . I have heartland one. Will check what years it works for rodrocket
    What area of Melbourne
  • rodrocket
    rodrocket
    7 years ago
    Thanks for that
    I am in Airport West, my son is in Craigieburn
  • robots
    robots
    7 years ago
    i have it, send me a message with your phone no.
    you wanting to remove the race?
