V&H Pro Pipe Short version
  • Ratbob
    Ratbob
    7 years ago
    The stock Pro Pipes imo are too big so I’d appreciate to hear from anyone running a set of the short version.
     Dyno sheets would be a good thing to share if you have em.
    Any general opinions on them also welcome.
  • Ratbob
    Ratbob
    7 years ago
    Wow, 134 views and no reply’s, I’m guessing these pipes aren’t popular.
    7 years ago
    Pro pipes seem to suffer a bit of of a poor reputation with the engine builder lads who prefer other brands. I dont mind them for the looks and sound but aware of heir shortcomings
  • FXDF08
    FXDF08
    7 years ago
    RR
    Can’t comment on the V&H 2 into 1, but can speak first hand on the Bassani Road Rage. Good performance, nice sound, good ground clearance. Worth a serious look. Over to you ...
    7 years ago
    I think you’ll lose a bit down low with the shorter pipe. How much you’d notice, if at all, is hard to say.
    It’s gonna be louder. And higher pitched sound. And closer to your ear than the longer pipe running behind the rider.
    Those are sufficient reasons for me to consider other options
  • Ratbob
    Ratbob
    7 years ago
    Hi guys, thanks for the replies.
    There’s a lot to think about with pipes. Just removed V&H Big Radius after a couple of months attempting to tame them with a few baffle designs, could only get down to 100db without reducing flow. The Bassanis are good, bit loud, nicely made. I’ll keep fishing.
  • Ratbob
    Ratbob
    7 years ago
    Hey thanks Hilly and there I was thinking Paulybronco was voted in as the big “C” :)
    7 years ago
    Quoting Ratbob on 01 Nov 2018 07:55 AM
    LOL I am the champ......but seems like there are contenders...
    7 years ago
    Quoting Ratbob on 01 Nov 2018 06:58 AM
    You must be talking about the 2-2 version, the 2-1 is a decent pipe with a really good sound, and not really loud.
    In general, I don't really rate V&H systems, but still they sell !
  • Drac
    Drac
    7 years ago
    I have the Rinehart racing 2 into 1 and find it quieter than most with a deep note
    Produces good power and torque
    103 hp and 113 tq I think from memory on 103 with s&s 570
    Now have 110 and head work same cams
    Tested at 98 db with a decent tester
    Mobile phone app 99 @ 2200rpm
    Have tried Rinehart crossbacks, good power but loud
    v&h big shots, good power less torque and loud
    Supertrapp fatshot 2 into 1, can move the power band and change the noise level
    Would be able to pass db test if needed
    Went back to RH 2 into 1 because best all round pipe for me
    Expensive experiment though
  • Ratbob
    Ratbob
    7 years ago
    Quoting speedzter on 01 Nov 2018 08:02 AM
    Hi speedster yeah it was 2-2, I did want the 2-1 but fitment info said no fit my CVO. Have to remove rear pegs, bit difficult for the missus.
  • Ratbob
    Ratbob
    7 years ago
    Quoting Drac on 01 Nov 2018 09:22 AMedited: 01 Nov 2018 09:22 AM
    Thanks Drac, I’ll see if I can find someone using them and have a listen. Cheers
