Online: brucefxdl
So, this wind buffeting thing...
1/4
  • kevinnugent
    kevinnugent
    7 years ago
    On the way home the other day with my new to me 17 SGS I encountered a considerable amount of wind buffeting.  Most appeared to be coming from up under the fairing.
    I use a good quality full face helmet, which seals the visor at the front.  And I think this may be to my disadvantage as once I cracked the visor open it stopped a lot of the head shuddering, eyesight blurring vibration through my head. Anything over about 90kph seemed to bring it back.
    I’m booked in tomorrow to get the adjustable side wind deflectors and a triple tree deflector installed.
    I don’t want to do without my $1k+ Shoei though.  Hopefully the deflectors will do their job.
  • Ratbob
    Ratbob
    7 years ago
    How tall are you? I’m a tad over 6’2” and get the same thing, mostly with head winds. Maybe you need the screen with the big kick up in the top lip.
  • kevinnugent
    kevinnugent
    7 years ago
    Quoting Ratbob on 08 Oct 2018 01:46 AM
    I’m going to trial a couple of screens as well there tomorrow.   I’m hoping I’ll get away with just the deflectors, as the wind over the screen seems ok. I’m about 6’1” so not far off you.
    7 years ago
    The deflectors i was referring to are not the fairing adjustable ones it the fork deflectors.......they aint ging to win any fashion prizes but wk well. The screen is the most important part of the puzzle. You need the top of it to be around the bridge of your nose height for decent airflow OVER your head at speed. The aero is crazy with these fairings and in the wet the rain on the front of my wet weathers gets sucked back off the suit and goes forward at 100kph! Shows the turbulence behind the screen
  • STEAMER
    STEAMER
    7 years ago
    Fork deflectors is what you want, they have Stainless HD ones, Plus try a Wind splitter screen, They have a flick up around top edge, HD have actually started making one this year, they work well,
    7 years ago
    These are the chrome fork mounted wind deflectors that stop the wind coming up from under the fairing
  • steelo
    steelo
    7 years ago
    Agree with the 10" windsplitter screen. Best I've had. (well only the second one I tried) post 14 tourers have the fairing vent which significantly reduces the buffeting. Looks like Tim also has the optional (SGs?) rotating plastic air deflectors under the fairing. Good on hot days to redirect air upwards but can cause buffeting when open. I couldn't find the chrome fork mounted ones anywhere to fit my bike. I think China and or Mickle once had them and made use of a dremel to fit them.
  • kevinnugent
    kevinnugent
    7 years ago
    I ended up getting a 10” Windsplitter fitted along with the adjustable deflectors and a triple tree deflector.  Reduced the buffeting by about 95% I recon.  Very happy with the results.
    The only thing with the 10” screen is I have to sit up pretty straight to see over the lip and took a while to get used to the optical distortion a bit.
  • kevinnugent
    kevinnugent
    7 years ago
    Quoting Tim S.G. on 10 Oct 2018 06:41 AM
    They aren’t that ugly Tim.  I may have a hunt around and see if I can find some.
  • Ratbob
    Ratbob
    7 years ago
    Quoting kevinnugent on 10 Oct 2018 07:01 AM
    Excellent outcome, enjoy the ride and with that distortion, be careful at roundabouts.
    7 years ago
    Quoting kevinnugent on 10 Oct 2018 07:03 AM
    They are a Harley part , in the Parts and Accessories Book
  • Spook
    Spook
    7 years ago
    That works for me also.
  • Steve L
    Steve L
    7 years ago
    Have a look at Freedom Shields in the USA. Ive had 2 of them now and highly recommend them. I'm only 5'7 and on my last Street Glide I only needed a 5' one. They are reasonably priced at $100 USD plus $60 USD for freight.
  • steelo
    steelo
    7 years ago
    Other options don’t make sense. 10” clear HD windsplitter screen about $230 from your dealer. Look great, work very well. Done 8k on the new bike with it.
  • mattt
    mattt
    7 years ago
    Quoting Steve L on 12 Oct 2018 09:18 PM
    Agree with you.  2011 SG, I'm 182cm tall and just rode around Australia with the 8" screen I've had on for 110,000kms since new. Works really well. Tried a 10" version briefly but it was to tall andI had to look through it.
    7 years ago
    As stated the best option is a screen you look over rather than thru
  • awaba
    awaba
    7 years ago
    The freedom shields, shields are optically correct as well,so no distortion with them,
    I ran a 7" screen from freedom shields ,now running a 5" works great...I'm 5'7"
    The rest of the kit is the chrome Harley fork deflectors (work well) and a kuryakyn wind deflector on the bottom tree
  • Baloffski
    Baloffski
    7 years ago
    Absolutely, seek over the screen, wind buffet are below. I placed a Kyrukin 10" screen on my ride, and worked perfectly. Lady would not come on ride with me before with shorter screen, as she was buffetted, and blown away on the back., Now happy girl on passenger seat.
  • kevinnugent
    kevinnugent
    7 years ago
    An update:
    Fitted 10” Windsplitter screen - triple tree wind deflector - adjustable under fairing deflectors.  Could not get used to the optical distortion in the 10” screen and the fact I had to sit up straighter to see over it so swapped it out for the 7” version.
    I reckon 90% of the buffeting is gone - and can simulate 100% by putting my hands out and blocking the wind coming up from under the front.  Also tucking my chin down slightly removed the effect.  I wear a full face Shoei and I reckon it’s contributing to the buffeting affect.
    Either I go with the fork mounted deflectors or try a open face helmet.  Everyone who has the fork deflectors seem to like the results.  On a newer 17 SGS where’s my best option to get them? HD dealerships?
    After this I have no more excuses.  Lol
  • graz
    graz
    7 years ago
    Go the fork mounted deflectors. Had them on 3 bikes now and they work a treat.
1/4
