Online: tussuck, softfat
CVO Road Glide.
  • steelo
    steelo
    7 years ago
    I think you’re right h&h.
    7 years ago
    Ha Ha see your getting old like the tourer boys......does look sharp
  • LOFTYBOB
    LOFTYBOB
    7 years ago
    I wonder where the radiators for the water cooled heads are? No stupid leg fairings is good
    7 years ago
    Quoting LOFTYBOB on 05 Oct 2018 11:14 AM
    Um that's a very good question Lofty....thinking this may be a pre water cooled with a paint job?
  • Ratbob
    Ratbob
    7 years ago
    Not bad from most angles, pity the fairing isn’t detachable.
  • LOFTYBOB
    LOFTYBOB
    7 years ago
    Quoting paulybronco on 05 Oct 2018 11:32 AM
    It's the latest 2019 CVO Milwaukee 8 RoadGlide, must be water cooled unless it is a custom engine build??
  • chriso
    chriso
    7 years ago
    Mmmm don’t mind it... what is the price range for the CVO fellas?
    Would also like to see the colour range.
    Looking at Mickle’s and chinas last night, fucken great paint schemes. Prob best paint colours I’ve seen.
    7 years ago
    Quoting LOFTYBOB on 05 Oct 2018 09:03 PM
    Seems we are both wrong, NON twin cooled motor
    2019 Harley-Davidson CVO Road Glide
    ENGINE
    Type: Milwaukee-Eight V-twin
    Displacement: 117ci (1923cc)
    Bore x stroke: 4.075” x 4.5”
    Maximum torque: 126 ft/lbs @ 3750 rpm
    Compression ratio: 10.2:1
    Valve train: Pushrod, 4vpc
    Exhaust: Dual, w/ crossover
    Cooling: Air
    Lubrication: Dry sump
    Transmission: 6-speed
    Clutch: Hydraulically actuated assist and slip
    Primary drive: Chain
    Final drive: Belt
    CHASSIS
    Front suspension; travel: Showa 49mm Dual Bending Valve fork; 3.6 inches
    Rear suspension; travel; Spring-preload adjustable Showa shocks; 2.2 inches
    Wheels: Gloss Black and Contrast Chrome Knockout
    Front wheel: 21 x 3.5”
    Rear wheel: 18 x 5”
    Tires: Dunlop Harley-Davidson Series D408F and D407
    Front tire: 130/60 x 21
    Rear tire: 180/55 x 18
    Front brakes: 300mm floating rotors w/ 4-piston calipers
    Rear brake: 300 fixed rotor w/ 4-piston caliper
    ABS: Standard
    DIMENSIONS and CAPACITIES
    Wheelbase: 64 inches
    Rake: 26 degrees
    Fork angle: 29.25 degrees
    Seat height: 26.8 inches
    Fuel tank capacity: 6 gallons
    Estimated fuel consumption: 41 mpg
    Curb weight: 884 pounds
    2019 Harley-Davidson CVO Road Glide Colors:
    Charred Steel/Lightning Silver/Black Hole
    Red Pepper/Magnetic Grey/Black Hole
    Mako Shark Fade
  • chriso
    chriso
    7 years ago
    3 colours to chose from, all not bad and would do but I think for that money I’d be wanting something I really like
  • Chaser
    Chaser
    7 years ago
    Quoting chriso on 05 Oct 2018 09:09 PMedited: 05 Oct 2018 09:12 PM
    With HD sales heading south at present, I bet if you approached a dealer at the end of the month you could grab one for 50K! No one pays RRP.
