Online: John.R, Merv
Clutch slipping problem
  • Cooch07
    Cooch07
    7 years ago
    Hi Guys,
    Needing some advise on fixing a slipping clutch problem on 2016 ultra limited, has only happened once in most gears from a standing start, spoke to my dealer and he has recommended putting in a Aim variable pressure plate assembly. Have already installed a heavier spring when engine upgrades were done, have been using the syn3 oil in primary for the last few services unsure about it ?
    Any recommendations would be appreciated. Cheers
    7 years ago
    Quoting Cooch07 on 01 Oct 2018 05:33 AM
    Hi Guys,
    hi Cooch, you could drain the syn3 and put ATF Type F in see how that goes, if it still slips use the AIM pressure plate. also is it more in high gear when it slips?
  • markwoumla
    markwoumla
    7 years ago
    Mate,, what upgrades were done, (engine wise) ???
    If nothing over the top was done , (say a cam upgrade, and it has the heavier spring), I am surprised you would have any slipping...
    When was the last time the clutch hydraulic fluid was changed, or even checked ???  With a late model bike, with no doubt not a lot of kms, I would start with the easy things..
  • Cooch07
    Cooch07
    7 years ago
    Hi Guys,
    Quoting Krash Kinkade on 01 Oct 2018 06:01 AM
    Slipped in first 4 to 5 gears, was considering changing to another oil so maybe look into that, thanks
  • Cooch07
    Cooch07
    7 years ago
    Quoting markwoumla on 01 Oct 2018 06:14 AM
    110 kit,cams 585 se, heads ported bigger valves etc an auto tuner I think there called, it constantly adjusts the tune to suit riding conditions.
    31000 ks. Haven’t changed the hydraulic fluid but looks to have normal colour, level is good.
    7 years ago
    If its already got a heavy spring in it then you have to think its the primary oil. I have the std clutch still in mine but heavy spring with around 70k and no slips and have run every oil you can think in the primary.
  • brash
    brash
    7 years ago
    Is the clutch adjusted properly at the ramp? It’s one people skip all the time before delving into the basket. It’s a simple check.
  • Cooch07
    Cooch07
    7 years ago
    Quoting brash on 01 Oct 2018 09:34 AM
    Unsure of that not familiar with how to adjust a hydraulic clutch, it was going to be my next thing to look at. My dealer suggested the variable pressure plate but unsure about it the more I read they sound like the clutch gets very heavy under high revs.
  • Cooch07
    Cooch07
    7 years ago
    Thanks Hilly
