Online: John.R
Extended forks regulations.
  • mrjessehlee
    mrjessehlee
    7 years ago
    Hi guys,
    Just wanted to see if anyone have experience with extended forks and the NSW legalities of it.
    Thanks very much!
  • John.R
    John.R
    7 years ago
    Quoting mrjessehlee on 25 Sep 2018 04:18 AMedited: 25 Sep 2018 06:00 AM
    Hi guys,
    Thanks very much!
    No offense, but if you're really concerned about the legalities of all your mods,  just get a copy of the Australian Design Rules and read it thoroughly.
    As for my experiences, mine are 2" over. Would anyone ever notice? Nope.
  • mrjessehlee
    mrjessehlee
    7 years ago
    non taken, I could read it but I'm lazy.
    why did you mod yours?
  • Ratbob
    Ratbob
    7 years ago
    It also depends which State you’re in and I don’t mean mentally:)
    Qld seems to allow greater trail. In Vic you see plenty of bikes with no front guards etc so you need the ADR and traffic acts that apply.
  • John.R
    John.R
    7 years ago
    Quoting mrjessehlee on 25 Sep 2018 05:55 AM
    Handles better and looks better. That length came stock on other models though.
  • Ratbob
    Ratbob
    7 years ago
    Yeah, I think springers are 2” under and a Fatbob is 2” less than a Wideglide and then there’s the rake issue which lowers the WG and Breakout, I’ve seen a few Breakouts with WG tubes and reckon the 2” lifts em nicely, couldn’t hurt handling.
  • Wideglider
    Wideglider
    7 years ago
    Quoting Ratbob on 25 Sep 2018 07:36 AM
    Yeah, Breakouts need all the help they can get with handling & ground clearance. Using WG forks seems to be the 'fix' for ground clearance.
    Mr J, I don't think cops really know - obviously as long as it doesn't look too radical.
  • mrjessehlee
    mrjessehlee
    7 years ago
    Thank you all!
    7 years ago
    You need to reference the ADR.  I do not recall seeing anything about length or rake/trail, HOWEVER the moment you modify the frame (ie the neck area) of exceed the 550mm rule then I suspect your open to being pinged.  Eventually I'm going to a Girder front end one day so have researched it a little bit.
  • mrjessehlee
    mrjessehlee
    7 years ago
    Quoting tussuck on 25 Sep 2018 11:12 AM
    Yeah I struggled to find anything about the length too. Anyway thanks for the info. Cheers.
  • Ratbob
    Ratbob
    7 years ago
    Quoting mrjessehlee on 25 Sep 2018 11:18 AM
    Yeah the rake and fork length are not part of the rules, they’re controlled by the 550 rule, that’s why you see some chop companies extending the neck of the frame so it looks like you have longer forks but within the 550 rule. Butt ugly I reckon.
  • mrjessehlee
    mrjessehlee
    7 years ago
    Quoting Ratbob on 25 Sep 2018 12:54 PM
    Yeah.. my question was pretty much found with 550 rule..
    Do you have a photo of the mentioned bike? Wld be interested to see what that looks like.
    7 years ago
    I think its the imported American Legend or some sort of piece of crap that tries and fails to emulate a 'chopper'.
    Oddly enough an aftermarket frame is sometimes the better way fwd so long as it comes with the Certs - although it will still need an Engineers certificate.  If your not worried then you can chop your frame and extend if needed, but make sure you do the rake/trail maths first.
    7 years ago
    this is NSW.
  • Ratbob
    Ratbob
    7 years ago
    Quoting mrjessehlee on 25 Sep 2018 12:57 PM
    Sorry don’t have a photo (not tech savvy) but look in Bikesales, there’s one bike under the make of Chopper, yellow and black, the forks ain’t long but they’ve pushed out the frame neck to compensate. Me no like but it’s likely to be within the 550 rule.
    7 years ago
    My mate just stretched his Honda shadow chopper.  Bought a set of trees and forks from the USA whee the trees are offset and the centreline of the neck altered as part of the kit.  Bolt on bolt off he said.
    7 years ago
    Quoting tussuck on 26 Sep 2018 10:11 AM
    Some tree's that have the rake in them, can affect handling, I've ridden old chopper panheads with raked frame & long front end, had to fight it at low speed, it also goose knecked over bumps, but surprising at the right speed.
