Online: John.R, Merv
Thundermax O2 sensor
    7 years ago
    Hey there,  my rear sensor is acting up and needs replacing.  Does anyone know if the sensor is the LSU 4.9 or LSU 4.2 type of sensor?
  • DJP_120ci
    DJP_120ci
    7 years ago
    Hey mate, can’t tell you what type they are but I know Rollie’s keep them in stock and they’ll run you about $150.
    Hope this helps.
    7 years ago
    cheers... I'll have a look at then then.  Bloody pricey @ $150 though.
  • Vic
    Vic
    7 years ago
    Replaced one of mine a while back tussuck , not sure what type they are but only id number on the box is 17014,
    not sure if its any good to you?
    If I remember correctly it cost me around 120 delivered after a search around on ebay.
    7 years ago
    Cheers...I removed the rear unit and the numbers on it are a standard Bosh LSU 4.2 device, so your right.  Your number is a LSU 4.2 as well.
    Too easy, I'll order two more tonight.
  • Daffy
    Daffy
    7 years ago
    Quoting tussuck on 21 Sep 2018 08:02 AM
    I bought a new Thundermax autotune unit from a guy on gumtree for $250.It is for a 2011 Softail though.He still has 3 more. Hope that helps. Pm me if you want his number.Cheers.
    7 years ago
    Cheers matey.  I see the Thundermax ones are bloody expensive considering they are simple LSU4.2 units.  Is the $250 just the autotune model or the ECU as well?
  • Daffy
    Daffy
    7 years ago
    Quoting tussuck on 26 Sep 2018 02:27 AM
    It's the whole lot new in the box
