Online: Merv
Bike Dolly are they strong enough
  • gidgi
    gidgi
    7 years ago
    4 point turns in the shed is a pain , was looking at some bike movers  on Ebay price  range from $140 - $240 unsure weather they do the job nicely or waste of money . Has any one used one of these  can you provide with some feed back Pls. was thinking they look pretty simple to make has any one done this? thanks
  • STEAMER
    STEAMER
    7 years ago
    Quoting gidgi on 20 Sep 2018 11:18 PM
    I had one of the cheap Ebay type, cheap wheels, no bearings, could not handle the weight.
     Then luckily i won a BikeSkate dolly. Worth every cent i reckon, ( even if i had to buy it ) which i did not. , quality bearing wheels, only rear wheel and stand fit on it. Bike can been spun around in own length
  • gidgi
    gidgi
    7 years ago
    Quoting STEAMER on 20 Sep 2018 11:54 PMedited: 20 Sep 2018 11:55 PM
    thanks Steamer will check out bike skate but will probably have a go at making one myself
