Dyna Superglide (Spoke Wheel) Brembo Brake Upgrade Compatability
  • jimmy.cee
    jimmy.cee
    7 years ago
    Hi guys,
    I've recently acquired my Dad's 06 Dyna Super Glide 35th Anniversary edition (image below) as my first Harley and the first thing I've noticed (after coming from a Ducati) is how terrible the front brake is. I've read around the forums and have considered two options: The Harley Brembo upgrade or going with a 4 or 6 pot Performance Machine. I've had good experience with Brembo before so I'm looking at that but given so many model variants and compatibility charts for general parts I can't work out if the Brembo will be a straight bolt on.
    I'm looking at buying this one and hoping it would be a straight bolt on: https://www.ebay.com.au/itm/Harley-Davidson-Brembo-Left-Front-Brake-Caliper-2008-2017-OEM/132786289266?hash=item1eeaadfa72:g:rUcAAOSwi2tboV6u
    Pic of the new ride:
  • John.R
    John.R
    7 years ago
    yes, will bolt up.
    The last 30 years of calipers are split up into 99 and under (the single pot calipers), and 00+ style mounts (4pots & brembos)
    The ONLY thing Im not 100% on is clearance of spokes, but I cant imagine it'd be a problem given you're current setup clears.
  • brash
    brash
    7 years ago
    another option is duel tokico's, one finger stoppies after that.
    7 years ago
    Bolted straight on (needed new mounting bolts) using touring discs, early Dyna though.
  • Ratbob
    Ratbob
    7 years ago
    Anyone tried the Arlen Ness big brake rotor kit ?
    7 years ago
    Only two finger braking needed .
    Yes, 06 on went to the larger 11.8" disc as standard, so they had to relocate the caliper mount position.
  • Benno
    Benno
    7 years ago
    Quoting Ratbob on 20 Sep 2018 12:39 PM
    I put the Arlen Ness kit on my Wide Glide last year, works a treat, get plenty of positive comments from other riders about it, there is a thread with pics in the product review sections, called Ness Big Brake Kit.
  • brash
    brash
    7 years ago
    Tokico's are off Japanese Superbikes etc, Speedmerchant make an adapter to bolt the straight onto the fork leg. Can even use stock Master Cylinder.
    I put the rear brake off a ZXR1000 on the back of my chopper and it was unbelievably strong.
  • John.R
    John.R
    7 years ago
    Quoting brash on 20 Sep 2018 10:39 PM
    I dont think those setups work for spoked wheels on narrow glide front ends.
  • fatslim
    fatslim
    7 years ago
    Nissin, Hilly, Nissin.
    XR1200.
    Need to use the 300mm disc that stock on the Slim S and other 2016 bikes.
    The XR1200 master cylinder improves things even further.
    7 years ago
    Quoting John.R on 21 Sep 2018 12:33 AM
    Yeah your right, I have several jappa calipers I bought thinking they would fit with no joy.
    In the end I just bought a set of solid spoke rims and now I can run any caliper I like.
  • John.R
    John.R
    7 years ago
    Quoting tussuck on 01 Nov 2018 03:22 AM
    Depends. Stock 9 spoke you're also limited, 108mm radials wont work because theyre too thick and hit the spokes, same deal with lots of jap calipers like the blue spot r1s ive got.
    13 spoke mags have a tiiiiiny bit more clearance letting you run 108mm  radials, albeit very little clearance.
  • Big Steve
    Big Steve
    7 years ago
    I'm going slightly different to the norm with mine fatty
    Brembo Monoblocs on Stunner Cycles mounts with Galfer Wave rotors..
    Similar to this:
  • John.R
    John.R
    7 years ago
    Quoting Big Steve on 01 Nov 2018 11:59 PM
    Similar to this:
    What wheels ya running?
  • Big Steve
    Big Steve
    7 years ago
    Similar to this:
    Quoting John.R on 02 Nov 2018 07:24 AM
    For now - OEM FatBob.
    Then Switching to 18s front and rear
