Thundermax autotune
  • Daffy
    Daffy
    7 years ago
    Hi all. Just bought a Thundermax with auto tune for my 11 Softail deluxe   Any problems with this unit?Is new in packet. I will install it and get someone computer savvy to do the rest. Any pitfalls?Do they work?  Cheers
  • Smokey61
    Smokey61
    7 years ago
    I've got one on the Widey I've owned for 9 months. Can't complain. Previous owner fitted it after a couple of V&H Fuelpaks failed on him. He swore by it.
    7 years ago
    Have run one on the Sporty for the past 3-4 years.  Great unit!
    Bought the cable on the internet and hooked up to my laptop and can tune to my hearts content.  or easy still is download and install the right canned map for the bike.  very easy to install and tune (tune in 30mins tops)
  • Daffy
    Daffy
    7 years ago
    I have my Thundermax now. Not confident enough to fit and tune it. Any recommendations in sa to do the job?
  • Daffy
    Daffy
    7 years ago
    Update on the thundermax.Fitted and tuned What a difference!Heaps smoother more response.Peter Stevens told me not to fit one of those things.Can,tunderstand why you wouldn't. No need for Dyno tune. Very pleased
  • LOFTYBOB
    LOFTYBOB
    7 years ago
    Quoting Daffy on 09 Oct 2018 10:49 PMedited: 09 Oct 2018 10:49 PM
    Neville Lush Racing at Victor Harbor, is the Dyno Guru in and around Adelaide mate if you need and work in that area.
  • Daffy
    Daffy
    7 years ago
    Thanks Lofty. No need for dyno. This thing is great!
    7 years ago
    Quoting Daffy on 10 Oct 2018 10:13 PM
    So only task now is if your running the Autotune is to get the changes to the Base Map that the autotune does written to the actual base map.  I presume that whomever fitted the thing has this already booked.
  • Daffy
    Daffy
    7 years ago
    Quoting tussuck on 10 Oct 2018 11:40 PM
    Yes we did the changes yesterday and it's even stronger now .smoothed out the line and saved it all.
