Online:
John.R
Superlow tyre options.
brash
7 years ago
It’s the “actual” width you have to worry about.
For instance a 170/70/16 shinko 777 is narrower than the comparative 160 Avon.
Best bet is to see if someone has fitted it before. But I was the guinea pig with the Avon and it took a lot of work to fit, relocating looms and slimline blinker studs and nuts.
brash
7 years ago
yep should work, just remember the wheels are offset on sporties so it's going to be closer to the right off the top of my head.
