Online:
John.R
Streetbob FXDB vs FXDBB Bars / cable / brake
David_E_676
7 years ago
Hi all !
I have a Streetbob with standard mini apes and I have purchased the 4inch riser with drag bars ( same as fatbob/ fxdbb). Obviously my current cable/ brake line is longer than what I need with the drag bars. I am disappointed that the clutch cable and brake line are not just a quick swap.. I would like to ask if the cable/ line changes are really necessary? I have noticed that the banjo out of the master cylinder is different ( mine points straight down and the fxdbb/ fatbob is a 90 degree banjo. Can I just cut the brake line up the top and put a new banjo and olive ? - I'm a bit concerned also about the bleeding with an ABS system as I have been told that I may need to have Harley dealership electronically bleed the ABS module.
Any help would be greatly appreciated.
TIA
Dave
