Online: Hilly, speedzter, Uncle Ho, Merv
Kesstech or Jekill & Hyde?
  • Muzza Wa
    Muzza Wa
    7 years ago
    So, does anybody have any comments (silly dumb fuckin question I know) or experience with either of the two adjustable “on-the-fly” exhaust systems? I want to know if anybody has used them and if you got through EPA testing, or through roadside pull overs etc. thanks guys.
    7 years ago
    Have you looked at the cost of these?!
  • Muzza Wa
    Muzza Wa
    7 years ago
    Yip. They pretty expensive but maybe worth the hassle in the long run if I’m gonna avoid the dreaded canary!
  • Ratbob
    Ratbob
    7 years ago
    Not seen these products before so I hope you get some responses. Considering the cost, as a Dyna rider I was disappointed to see they don’t offer full systems.
    Dyna headers are crap.
  • Muzza Wa
    Muzza Wa
    7 years ago
    Quoting Ratbob on 09 Sep 2018 12:20 AM
    I think they do, they have a new configuration tool. Apologies if you checked but I thought I saw headers for the Dyna.
    7 years ago
    Muzza I don't have experience with either of those options but I did have another similar exhaust, a patriot defender. It had a movable flap to adjust sound and flow. The flap was rigged up to a cable and lever on my handlebars.
    It worked very well and achieved my objective of being able to be stealth in a moment. I used it to start up and ride quietly out of my neighbourhood at dawn.
    Eventually the carbon build-up in the exhaust made it difficult to move the flap. I think if you were fastidious in moving the flap very regularly it may not jam up as much.
    I eventually sold it for another pipe but mainly because I forked out $ on a 107 top end build and to get the most out of it I wanted a good performance exhaust. I used the supertrapp 2-1 exhaust at the recommendation of the engine builder and also the tuner. It also conveniently happens to be one of the quieter exhausts which you can tune for flow/noise by adding/removing discs. They also have a closed end cap option which makes the sound very quiet.
    The jeckyl and Hyde exhaust was around when looked into this as was the peacemaker but both were/are very exxy and I couldn't justify the cost for something that was relatively unknown..
    The concept with these exhausts is clever. The flow between open and closed is very different so I'd recommend you only change the flow/noise for when needed as otherwise your tune is out. Unless you had a power vision or similar where you can readily change between two different tunes.
    The risk with the flaps that open/close/move to make these exhausts work is that they fail or jam up whilst operating in a very hot and sooty environment. I'd be pissed off if this happened for a costly exhaust.
    You can avoid the risk of being defected via other means. My supertrapp and choosing where and when I make noise has helped me.
    Good luck and let us know what you do
  • Muzza Wa
    Muzza Wa
    7 years ago
    Quoting fatbat on 09 Sep 2018 01:41 AM
    Thanks Fatbat, I did see your posts from 2012, I think they were. I have FP3 tuner so on the fly reconfiguration of the ECU is not possible, I’d use the quiet option only when needed, to avoid annoying my neighbors and the cops. Interesting that the butterfly valve got chocked with carbon though!
  • Muzza Wa
    Muzza Wa
    7 years ago
    Seems like there is, for once, not even a sarcastic interest in this subject, which to be honest surprises me considering the shit we face with noise all over Australia!
    What’s up with you PB? The nominated cunt of the forum suddenly gone quiet, maybe you not a cunt after all! Lol. You know where that came from!
  • Muzza Wa
    Muzza Wa
    7 years ago
    BTW Fatbat, Jekill & Hyde do offer an extended two year warranty which makes me feel they serious about their quality and the products longevity.
  • Muzza Wa
    Muzza Wa
    7 years ago
    Found another supplier/manufacturer MCJ !
    7 years ago
    Good stuff muzza will be interesting to see how this goes
  • Muzza Wa
    Muzza Wa
    7 years ago
    Kesstech are offering 4 year warranty!
    7 years ago
    I hadn’t heard of them. Looked them up and look good. Until I saw the price. When converted from euro to aud, a pair of mufflers was $3,800 aud.  And that’s not including shipping. That’s the problem with some of these products. German products make a habit of this
  • Muzza Wa
    Muzza Wa
    7 years ago
    What about these!
    http://www.nationalcycle.com/media/wysiwyg/pdf/documents/Peacemakers_VTwin.pdf
  • Muzza Wa
    Muzza Wa
    7 years ago
    Agreed
  • Muzza Wa
    Muzza Wa
    7 years ago
    So, I have pretty much “exhausted” my options to quieter down my V&H Big Radius pipes, I may try one more option, but it’s a long shot and I will explain my idea and seek feedback from you all, but first, what have I tried......
    Well as you know, I tried the Smartpartz baffles in behind my V&H standard baffles, and although they made a slight difference in the sound and definitely gave me better low end torque, they are still no where near compliant, so, next I ordered and installed the V&H Quiet Baffles, the loudness difference was 1 DB! So next I tried the Smartpartz & Quiet Baffle combination and well it made no fucking difference, funnily enough, my Buttdyno also saw no difference in the Torque, I.e. it does not appear to me that I’ve chocked the engine with the quiet baffles, it feels like it runs the same.
    So, how’s about this for an idea, and before you all groan, I really like the look of the V&H BR and they compliment, in my opinion, the look of my bike, but I also don’t want to look like a canary tree with all the yellow noise stickers I’m likely to pick up, hence my quest to quieten them down to legal levels. The stock exhausts come standard with an exhaust flap that’s connected to a servo motor (exhaust actuator), that’s connected to the ECU, from what I’ve read and observed, the flap is opened and closed at certain RPM, most importantly it seems it’s closed at the RPM limit defined on the sticky label on the frame that defines the dB loudness at 2505 rpm. This configuration is only present on 5HD (export) models, and is there, apparently, to meet Australian and European EPA requirements, for both noise and emissions.
    So here’s my thinking, does anybody think that I could modify my BR’s to include the flaps, one in each pipe, and reinstall the actuator and that it would actually work? I notice that the FP3 has a setting for active exhaust, which is turned off by default when you select BR pipes, but you can turn it on if you like. If I could figure out what signal the actuator needs to close the flap, then possibly I could trigger that signal, via a switch, when I need to be quiet. It’s a long shot, but I don’t want to start hacking my BR pipes up and then welding in the flaps for no good reason!
    As always, your comments and opinions will be well received.
  • Ratbob
    Ratbob
    7 years ago
    Hi Muzza
    You pose and interesting proposition, I too like the VHBR but hate the volume with my 110 engine. I tried some different ways, bigger then longer baffles then wire suppositories which worked to get 93dB at 2500 rpm but it didn’t feel right. The others made very little difference.
    I think the electronic idea is good but beyond me. Good luck
  • Ratbob
    Ratbob
    7 years ago
    Heard a new 114 Breakout today with V&H BR pipes. The 4 valve heads sure change the sound, freaking thing was about half the volume of my 110 Twin Cam.
    Get one of them Muzza, problem solved, well, exhaust problem solved.
  • Muzza Wa
    Muzza Wa
    7 years ago
    I hear you Ratbob, but I’m not listening......I love my 2016 Fatboy Lo, it’s the last of the Lo’s made.
    I see you have also tried many things to quieten the VHBR down, to no avail.
    I have investigated the FP3 and the exhaust actuator and I am able to program the % open/closed at any point in the rpm range, which helps from an information perspective, ( I.e. the actuator is a servo driven device, not on/off) but.....what I need is to override the FP3 when the bike is in neutral and on the kickstand and revved to 2505, but it’s not possible to program that logic in to the FP3. They are not going to test you for noise in gear while someone holds the bike up! I guess what I am trying to do is what VW got caught doing.....override the system to suit EPA test conditions, hahaha.
    I shall however, persevere!
    Maybe I can get the system mechanism and electronics from Jekill and Hyde without the exhausts? I’ll try them.
    Thank you for your interest and contribution to the thread.
  • Ratbob
    Ratbob
    7 years ago
    Cheers Muzza
    Whether using a Super tuner or FP3, Won’t the sound valve be closed at idle, in gear or not ?
    I understand that with two valves you’ll need to have them partially open at idle for flow but that could also be achieved by drilling the valves so they can close and maintain a desired flow rate, just add more holes till you get it right ?
