Online: tussuck
CVO battery
  • ralphski
    ralphski
    6 years ago
    my battery is on it's last legs.
    holds ok charge, but when it cranks over drops to about 5.5 volts.
    which barely cranks over my CVO Springer.
    got about 5 years out of the HD 65989-97C.
    thinking of maybe a SSB PowerSport RTX20L-BS.
    both have 1 year warranty, HD about 315 CCA, SSB about 400 CCA.
    price....HD  $200, SSB   $135
    thoughts, pro's con's ????
    6 years ago
    Pay the money and get a Gen HD battery! Would NEVER get a non gen HD battery again
    6 years ago
    Quote source removed.
    Why is it shitting on your tender...
    6 years ago
    I've always used genuine HD AGM, but have seen a few people be let down by them in past few years. a good friend, went from Genuine HD to that same SSB you quoted and no problems 1.5 year on. have seen others give the SSB a good rap too.
  • ralphski
    ralphski
    6 years ago
    bought a SSB RTX20L-BS, $ 88
    time will tell.
    normally buy HD batteries, did buy a DEKA for the Night Rod.
    it only lasted about 2 years, wasn't fckn happy.
  • steelo
    steelo
    6 years ago
    That’s one year longer than it’s warranty r.
  • Retroman
    6 years ago
    Have tried DEKA's over the years , seemed OK.
    Trouble is the genuine HD batteries ( made by DEKA anyways !) work out cheaper from the HD dealer , strange but true !
    Have had mates try Odyssey and other "exotics" over the years and always they come back to "genuine".
    With battery Fighter junior tenders I have had "Genuine" batteries last 7 years on a few occasions before now.
    Will be interesting to see how these "$88" SSB batteries pan out
    6 years ago
    Been a fan off ssb battery’s for a few years now  more cca than a HD Oem one  shit
    All over deka gray shit I’ll never buy one of them again  and  as I’ve said in
    The past  if you remove the stickers off the ssb you would swear it’s a HD one
    Look exactly like each other ot than the HD one has the bar n shield molded
    In the case    Ive only ever used the gel Matt type hvt1 I think  which is 420cca
    No one can tell you what the HD ones are exactly but there apparently around
    315cca  and as hilly said bugged if I would ever use a wet type battery in
    A harley  with a oil tank heat spewing acid all over chrome and paint destroys
    It in no time even with a vent hose going unde4 the Bike  if can afford to do
    Engine upgrades don’t be a tight arse on a cheaper battery that’s my 2c
    Ssb 1st than  Oem HD 2nd in my bikes. Deka gray door stop lol
    6 years ago
    I will be trying an SSB next time (HVT-1 $120 delivered ).
    I usually get 2 years out of the HD replacement battery, but they struggle before then.
    Not as good as they once were.
    When are these high tech Lithium's gong to be sorted out for reliability , and sell for a decent price ?
  • newschool
    newschool
    6 years ago
    I use SSB Drycell (V-SPEC)  in my 110CI. Due to frame mods with lowered seat height I need the VTX15L-BS (175L x 87W x 130mm High) which specifies 340CCA. Even after 2 weeks cold soak in VIC winter it still cranks strong.
  • ralphski
    ralphski
    6 years ago
    surprise fckn surprise....
    fully charged the battery then fitted to bike.
    after 2 days turned on the ignition, lights were low, tried to crank the bike.
    nothing.
    put the meter on, 12.5, but turn on the ignition drops to 9.5.
    6 years ago
    Some use cylindrical cells.
  • Ratbob
    Ratbob
    6 years ago
    Quoting ralphski on 14 Sep 2018 04:19 AM
    nothing.
    I don’t know anything about SSB batts or batts in general really but given your experience I’m wondering what type of charger you used. I killed a friends batt after he lent me his BMW GS by using an old fashioned manual charger, bought a new one and was told to use a Cteck or other smart charger on the AGM setting or it will cook the cells.
  • ralphski
    ralphski
    6 years ago
    bought a SSB DRY CELL BIKE BATTERY HVT1 450CCA
    seems to do the job no worries
  • Vic
    Vic
    6 years ago
    Quoting ralphski on 14 Oct 2018 08:56 AM
    Good to hear, was just checking out batteries for my springer which has the rtx20l-bs in it at the moment.
    But the htv1 looks to be the better option.
    6 years ago
    Fitted the HVT-1 SSB a few weeks back.
    Spins the 120 over OK with both ACR's engaged, as it should.
    Time will tell I guess.
    The old Genuine battery was 3 years old, and would probably still be ok for a stock motor.
    Interesting thing, the new SSB holds a resting voltage over 13v.
  • 98fxstc
    98fxstc
    6 years ago
    I got the HVT-1 midweek
    Did a bit of reading up on it and it reads pretty good.
    Impressed so far
    6 years ago
    Hilly, 13.7 volts is around the correct float charging voltage for standby use.
    Below is a chart for the batteries state of charge after resting for at least an hour ( all depends on Battery chemistry of course )
  • ralphski
    ralphski
    5 years ago
    SSB Ultra Performance 12V 450CCA HVT-1 HD
    well after about 15 months the battery is fckd.
    full charge 12.9, ignition on 12.3, cranking 5.2
    and i thought it was a 2 year warranty, fck
    HD or buy another SSB HVT-1 ?
  • Retroman
    5 years ago
    Sorry to hear that mate BUT seen it all before..
    I work on Harleys a fair bit and will only fit a Genuine HD battery for myself ( OR OTHERS) now !
    Trouble is the nearest Genuine HD dealership is now over 40K's from me since Frasers left town FFsake...
    Even my electronics tech riding mate has given Odyssey the flick and is now a "Genuine HD" convert again haha..
