LOW RIDER TYRES
  • boxa
    boxa
    6 years ago
    Just wondering what are people running on there dynas ,I'm up for new tyres , done 10000 klm on the originals  and both front and rear need replacing , 10 grand is probably not to bad , i'm not opposed to the original dunlops but have people got better mileage and handling out of others , for sake of handling in the wet and dry , i don't care if i get a bit less mileage  , but would be nice to get better mileage and handling ,, suggestions please
  • WideglidingNZ
    WideglidingNZ
    6 years ago
    Pirelli Night Dragon, Metzeler ME888, Dunlop American Elite, Michelin Power Commander and Avon Cobra seem to be the tyres of choice, I have run both the Metzeler and the Pirelli both were better than the original tyres, I am using the Night Dragons now because they were the best deal at the time (cheapest), do a search there is plenty of info on this site on tyres
  • binnsy
    binnsy
    6 years ago
    Replaced a front tyre on my fatboy with an Avon Cobra and made the front end behave a lot better.  Will put one on the rear soon which is due for a new one.  Very happy with them.  Cant comment re wear yet.
  • brucefxdl
    brucefxdl
    6 years ago
    have a pair of commander 2,only got 3000km on them so far,improved turn in on roundabouts,good wet weather feed back and a smoother ride at the same settings/pressures on the same roads.happy so far
  • offbeatmammal
    offbeatmammal
    6 years ago
    I used to run Metzeler ME888s on my Dyna (05 FXDLi) and loved them. Great in the summer heat and kept good traction in the rain (important, as I was in Seattle!) and lasted pretty well though took a little longer to break in than the Dunlops so take it easy for the first 150ks
  • boxa
    boxa
    6 years ago
     Does'nt seem to be much difference in price from one make to another , 50 bucks from lowest to highest , not worth haggling about , dunlops being the highest , and i don't want them anyway ,,,  the cheapest is from a harley dealer but  in honesty i don't want to use them , they done the last 2 services and both times  i then had to take it elswhere to get the belt adjusted , after they gave it back too tight or too slack  , so there out ,
    Leaves me with   a choice of bridgestone cruisers , or michelin commander2 ,price about the same ,, never used any of them , so thoughts  from people who have
  • dyna13
    dyna13
    6 years ago
    Cobras on a 13 wide glide were great
  • Jayman6
    Jayman6
    6 years ago
    Avon Cobras on Fatbob. Great tyre, nice and sticky, good for about 10-11000kms.
  • JFE
    JFE
    6 years ago
    Quoting Jayman6 on 05 Sep 2018 08:53 AM
    +1.
    I’m happy with Cobras on my FXDF. Would add they are sensitive to correct pressure, but I like them wet or dry. Plenty of blokes swear by Night Dragons too.
  • chriso
    chriso
    6 years ago
    Pirelli night dragons for me great in wet and dry. I get 10,000 out of em and they get a caininhg. Always keep the rear pressure above 40 psi though or they will wear flat.
    As the fellas have said Avon cobras are good too. I have experimented and they the only two I run.
  • Benno
    Benno
    6 years ago
    Recently put Avon Cobra's on both front and rear of the wide glide, feel much more confident in the corners than compared to the dunlops that I was running.
    6 years ago
    If anyone wants a near new rear 160/17 Night Dragon cheap ($100 + post) , let me know.
    Removed it after around 500kms due to no traction.
    Came from EasyR , but i'm guessing it was old stock .
  • steelo
    steelo
    6 years ago
    What a sales pitch!! Snap this one up folks.
    6 years ago
    It would be fine for a lot of guys with stock power that don't ride hard  ..........
    Really no worse than a Metzeler 880.
    At least I was being honest !    :-)
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Got the night dragon on the front of my FatBob,  and I think it is a huge improvement on the standard tractor tyre. Still have a 1/2 life oem style Dunlop on the rear, tossing up my options there, either a matching night dragon or maybe  the bridgestone battle cruise.
  • JFE
    JFE
    6 years ago
    Ken, go the Night Dragon and make the set. Plenty of blokes swear by them, particularly on Dynas.
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    Yeah probably will end up going that way. Was considering the Bridgestone for potential longer life span due to the duel compound, but havn't seen any real life feedback on them.
  • R2D2
    R2D2
    6 years ago
    Quoting steelo on 06 Sep 2018 04:39 AM
    http://www.totally-cuckoo.com/26.03.10%20wrecked%20Harley.htm
  • chriso
    chriso
    6 years ago
    Agree with all that
  • Benno
    Benno
    6 years ago
    Quoting Ken in Cairns on 06 Sep 2018 11:05 AM
    Ken, your conditions are unique, I have seen a few guys hit the mould covered painted lines on the ranges up there and come to grief cause they were stingy buying tyres.
    New tins and paint cost a lot more than good rubber.
    Benno
