red leads
red leads
marce
7 years ago
Winter is done, time to spend more time on the bike I recon.
does anyone know the best place to get some red spark plug leads for the 103 ?
I did see some SE ones on Ebay from the states, but was a lot of $ for a couple of small leads.
m
Muzza Wa
7 years ago
I got mine from DK Customs, they work just fine.
98fxstc
7 years ago
after market plug wires and plugs (including Screamin Eagle) are known to sometimes cause problems with the ion sensing system
if you have any work done on the motor, particularly increased compression, much more likely to have problems
you will have timing pulled due to false knock and performance will be affected
if you have a stock motor, you are less likely to have problems , probably not something you will worry about
you can hook up the vci and do a ride log to check whether you have a problem
Drac
7 years ago
I have screamin eagle ones on my 2012 fatty
They were under $50 from morgan & wackers brisbane
marce
7 years ago
beaudy!!! $41 bucks from dealer(screaming eagles).
Thanks for all the help.
m
