FXBB number plate mount
offbeatmammal
7 years ago
while there's not much of the look on my Street Bob that needs changing, the factory number plate/brake light is just a bit messy ...
does anyone have any recommendations for (something like) https://www.hotbike.com.au/?product=opt5-fxsb-inner-fender-fix-black-black-license-plate-frame-led-indicators or https://www.customdynamics.com/radius-quad-horizontal-motorcycle-plate-frames-with-flushmount-leds-led-plate-illumination?cat=2 that'll fit flush up against the rim of the fender and supplement the existing lighting (and of course if compliant/street legal in VIC **Edit**: looking at these - http://www6.austlii.edu.au/cgi-bin/viewdoc/au/legis/vic/consol_reg/rsr2009309/s48.html - I suspect 'flat' may be an interesting discussion)
JSA
7 years ago
JSA
7 years ago
JSA
7 years ago
I agree so I made this up as soon as I got it home. Bit of 3mm aluminium shaped and drilled to bolt straight on to underside of factory steel gusset under fender.
Painted black looks tits
offbeatmammal
7 years ago
damn, that looks like what I want ... though for compliance I'm guessing it also needs the reflector and number plate lights.
reflector could go at the bottom and still keep it looking good, and something like these - https://www.thirdgear.com.au/license-plate-bolt-lights-black/ - could give it the light...
you need to open an Etsy store and I'll be your first customer ;) [recently moved back to AU from the US and have no access to a workshop, or for that matter mechanical skills!]
JSA
7 years ago
Thanks mate. Forgot to mention it does have the number plate light. It’s a small led one under the fender. I’ll take a photo later on when I get home.
Turned out well for an hour or so work... considering the outrageous price of the aftermarket ones out there
offbeatmammal
7 years ago
I think you need to have a reflector in VIC as well don't you? Trying to minimize 'reasons to annoy VicPOL" :)
serious question ... would you be open to making/shipping one my way and if so, how much? I suspect there's a lot of FXBB (and some of the other Softails) that would keep you in beer money for a while!
JSA
7 years ago
Reflectors, pffff. You just reminded me I think the number plate mount was the SECOND thing I did straight after I peeled all the bloody reflectors off
I’m about to make one up for a mates new breakout. I’d be happy to do more
offbeatmammal
7 years ago
yes please! PM'd you ;)
you might need to set up a production line if word gets around!
