Online: fatbat
Fat bob riser measuement
  • Cruiser Al
    Cruiser Al
    7 years ago
    Hey all, can I ask a small favour of someone with a fat bob, or fat bob bars?
    I’m away from my bike as I work away in the desert (Moomba) and am wanting to machine some spacers while I’m here to bring my bars up a bit.
    Could someone possibly measure the diameter of the stock black risers at the base where they flare out a bit?
    Pic below is what I am trying to achieve!
    Thanks in advance!!
  • Ratbob
    Ratbob
    7 years ago
    I have a set off the bike so easy to measure at the flare, they are 41mm or 1.6 inches, so that’s with the powder coating thickness whatever that may be , cheers
  • Cruiser Al
    Cruiser Al
    7 years ago
    Many thanks to you Ratbob! Appreciate it mate!
  • Ratbob
    Ratbob
    7 years ago
    Hi Al, I was taking some measurements of the risers and noticed that one is 41mm at the base, the other is 40mm, so I assume the black coating must be inconsistent. Thoughts I should let you know. Cheers
  • David_E_676
    David_E_676
    7 years ago
    Hi guys, I just happens upon this thread and thought it would be a good place to ask my question. I have a stock Streetbob with forward controls and was thinking about changing bars and risers to a stock fat bob . Are fat bob bars comfy? I am 175cm tall
    TIA
    Dave
  • Cruiser Al
    Cruiser Al
    7 years ago
    Cheers for the update Ratbob!
    David, I find them quite comfortable! I would prefer the street bob bars for looks though! Do you not like them?
    I have forward controls on my Super glide and am 178 tall
  • David_E_676
    David_E_676
    7 years ago
    Quoting Cruiser Al on 02 Sep 2018 08:45 AMedited: 02 Sep 2018 08:45 AM
    Thanks Cruiser Al, - I don't mind the stock Streetbob bars/riser, but it puts a lot of weight on your hands at higher speeds and they become less comfortable. I was considering T bars ?? ... What height are the stock fat bob risers?  I have heard That they are anything between 4 - 6 inches depending on where you look or who you ask...
  • Cruiser Al
    Cruiser Al
    7 years ago
    I believe they are 4-1/2” but am away from my bike so I can’t be certain, though that does seem about right from memory.
  • Ratbob
    Ratbob
    7 years ago
    Dave, the Fatbob and Wideglide risers are the same. Fatbobs run a flat bent back bar and Widies run a raised bent back bar if that makes sense. The risers are considered to be 5 inch but that’s measuring the riser from top to bottom (not including the top half) and does not take into account the half round cut out that the handle bar sits in. So from their base sitting on the triple tree to the bottom of the curve which the bars sit in they measure 111mm or 4.37 inches. Hope that helps.
  • David_E_676
    David_E_676
    7 years ago
    Thanks for the info Ratbob and Cruiser Al. You guys have been a big help
    Sorry for hijacking the thread.
    Cheers n Beers
    David
  • Big Steve
    Big Steve
    7 years ago
    Quoting David_E_676 on 02 Sep 2018 09:22 AM
    I have one Fatty with apehangers and one fatty getting tall risers/MX bars.
    Those are Wideglide bars/risers in the bottom pic (you can rotate these to get a bit more height)
    Best of both worlds
  • Cruiser Al
    Cruiser Al
    7 years ago
    Quoting David_E_676 on 02 Sep 2018 11:13 PM
    Cheers n Beers
    David
    No probs David!
    If we lived closer we couldve organised a possible swap over some beers!!
    Very nice Big Steve!!
  • David_E_676
    David_E_676
    7 years ago
    Cheers n Beers
    David
    Quoting Cruiser Al on 03 Sep 2018 04:21 AM
    No probs David!
    It's only about 1500km... ?? Just a short ride, but would be worth it for the beers ??????
  • Cruiser Al
    Cruiser Al
    7 years ago
    Haha, yep!
    Well, I’ve machined up a pair of 40mm tall x 38mm diameter (convenient and rather high grade stainless steel) bushes and have given them a coat of gloss black! Will have to wait until Friday when I get home to see how they go!
  • Ken in Cairns
    Ken in Cairns
    7 years ago
    I fitted the same wideglide bars  as Steve, but it still wasn't enough, tried the same idea off a packer, but I needed it moved back as well as up, ended up with HD curved 6 inch risers. Not cheap but did the job perfectly. Hope you had some 7/16 x 14 tpi bolts 40 mm longer than stock laying about too ??
     Ken
  • Cruiser Al
    Cruiser Al
    7 years ago
    Not laying around, but I’ll just head over to Coventry fasteners to get what I need! So the boots are 7/16”? I was reading 1/2” but being away from my bike makes confirmation difficult!
  • brash
    brash
    7 years ago
    How tall are those Wide Glide risers Big Steve?
  • Ken in Cairns
    Ken in Cairns
    7 years ago
    Pretty sure it was 7/16 unc. I'll check today if I get a chance.
  • Big Steve
    Big Steve
    7 years ago
    Quoting brash on 03 Sep 2018 10:10 PM
    Do you mean the raw ones?
    They are 8" risers and 4" rise on the bars.
  • brash
    brash
    7 years ago
    Quoting Big Steve on 03 Sep 2018 11:23 PM
    Thanks mate. Yeah those ones. They have a hole in the risers to run the wiring through?
    I can grab a set of those second hand a lot cheaper than a set of hardcase ones.
