Online: beaglebasher, DIVOT
vpw rear wheel
  • Sue4044
    Sue4044
    7 years ago
    hi all Ive got a 2010 Dyna wide glide Ive just put on vpw  king spoke wheels front str8 in no problem, rear went str8 in pulley side no problem with standard spacer..... but disk side i had to cut 4mm off spacer and used what was left, around a  20 mm spacer  as pic shows ... and the 4mm spacer   i had to use from swing arm to brake caliper bracket, wheel is center, brake caliper is now center on disc ...Ive had a mate tell me i cant space out the rear brake caliper the way Ive done it is he right or am i wrong thanks no i am totally  paranoid
  • Far Canal
    Far Canal
    7 years ago
    Best to ask VPW.
  • Sue4044
    Sue4044
    7 years ago
    Quoting Far Canal on 21 Aug 2018 08:34 AM
    Best to ask VPW.
    would definitely do that, only they don't know anything about spacers at all
  • Sue4044
    Sue4044
    7 years ago
    hi hilly ive just put pic up of front mount
    7 years ago
    The spacing of the caliper looks perfectly functional .
    I recently did something similar when trying to center a wheel, but using a 3mm spacer (stainless washer !). No problems.
    I don't think it would be possible to fit a disc spacer as thin as that and still retain the boss that centers the disc on the wheel.
  • Sue4044
    Sue4044
    7 years ago
    Quoting speedzter on 21 Aug 2018 09:32 AM
    thanks for Ur time hey i thought it would be fine just started 2nd guessing myself after my mate said u cant thanks to the both off you
    7 years ago
    I run wide glide wheels on my softails  and have done pretty much the same thing as you
    As I centred the wheels  but I kept the pulley side same  position as Oem would be
    Than spaced the brake side by machining caliper and spacers  for the brake side  just
    Make sure your disk is in the center of caliper   And As hilly said you can get that
    Spacer and even thinner ones from Vulcan engineering in the USA   And drag Specialties
    Make super thin pulley/ disc spacers swell  like the others have said as long the
    Caliper is located enough you shouldn’t have any issues
  • Sue4044
    Sue4044
    7 years ago
    Quoting perthhog on 22 Aug 2018 01:08 AM
    thanks to all for ur time in helping me out its great that we can come on here and seek help thanks again
    7 years ago
    The disc spacer won't work as I have stated. Due to the thickness needed, you wont be able to correctly retain the disc cenetring boss.
    What I will say after looking at the pics is the spacer you used may be a bit undersized.
    Use a spacer that is the same size or slightly larger than the caliper bracket O.D.
    7 years ago
    Yep depends what thickness is needed but you can buy them with out the boss  made
    Out of thin metal  to the thicker alloy type  but yes you need that boss support
     Then there’s the fact that there’s different size hub boss aswell    Evo to Tc
    As there mammoth  aftermarkets  maybe evo ?  Or Tc
    Should change your brake pads too to Lyndals aswell. Lest brake dust on all those spokes cleaner for a lot longer  lol
  • mitch199
    mitch199
    7 years ago
    Hi mate,
    For what its worth I recently did a similar job on my 09 Dyna Low Rider, threw a 200 Softail wheel under it off a Fatboy.
    To fix your problem could you move your spacer from its current location to between the hub and the disc? I had to muck around a lot with spacers on my wheel conversion, mm too much here, mm too much there, was a lot of on-off wheel installs until everything worked perfectly after torquing the axle down and not having the disc bind up or rub anywhere, on the belt side and/or pipes side of the disc.
    Your bike will look sick with the new hoops.
  • Daggs
    Daggs
    7 years ago
    Should be fine but I would use a larger diameter washer. I had to do the opposite with my rear wheel mod, machined some off the caliper mount to move it all over more to the right then machined a wider left hand spacer. Also machined a pulley spacer to get the belt away from the tyre a bit
  • Ken in Cairns
    Ken in Cairns
    7 years ago
    Yep me too Hilly. The one at work is 3500 km from home :(
    Hare and Forbes do some good small ones, the metalmaster series, had one on the last boat I was on, gonna miss it.
    To the OP, fit bigger diameter spacer on the axle as has been said, and if you are worried about the mounting bolts not having the same reach as the stock you could buy some slightly longer ones and cut them down to the length of the stock bolt plus the new spacer, but I don't think a mm or two would be a concern really, any more defiantly would warrant some bespoke bolts.
    Ken
  • Liam
    Liam
    7 years ago
    Quoting Sue4044 on 21 Aug 2018 08:25 AMedited: 21 Aug 2018 08:49 AM
    As long as the spacers are the same as stock between the wheel and the caliper then you can do what you want past that.
    HD Mech
  • Sue4044
    Sue4044
    7 years ago
    thanks to all for ur help much appreciated
  • Dan069
    Dan069
    7 years ago
    Hi Sue I have the same wheels did you use inner tubes as mine keep going flat thanks Daniel
  • jocky
    jocky
    7 years ago
    Quoting Dan069 on 17 Sep 2018 08:27 PM
    hi dan069. luck of the draw with those wheels,i have the same ones on my "Bobber Build". front one leaks,rear is ok
    The problem is that they have a strip of sealer around the inside of the rim,and if not perfect air will leak though the
    spokes,you could try to reseal it or just put a tube in like i did...jocky. just finished my build waiting on the engineer
    pics soon.
  • Dan069
    Dan069
    7 years ago
    Quoting jocky on 18 Sep 2018 12:26 PM
    pics soon.
    Hi jocky thanks
