Online: Soapbox2627
Tour Pak (Top Box)
  • Chaser
    Chaser
    7 years ago
    After a 2014+ model tour pak with hinges, locks, lights etc attached. Don't care what colour it is, just needs to be genuine. Thanks
  • steelo
    steelo
    7 years ago
    Good luck Chaser. Is this for your bike or another one? I would have thought that a S/H one would be like hens teeth although I remember seeing some lookalikes (I know you said you want original) on Ebay.
  • Chaser
    Chaser
    7 years ago
    Quoting steelo on 20 Aug 2018 05:15 AM
    Heaps of Chinese ones on ebay.....cheap but sometimes can be more hassle than it's worth. Can get a primed one through HD here for $1000, then paint, lights, hinges, locking piece etc etc.  OUCH! Rock and a hard place.
    7 years ago
    Quoting Chaser on 20 Aug 2018 05:20 AM
    Try these guys, i bought some lowers and TJU some bags and bits. Their color matching is excellent and free freight to Aust...
  • Chaser
    Chaser
    7 years ago
    Quoting paulybronco on 20 Aug 2018 10:33 PM
    Thankyou sir!
    7 years ago
    They have an excellent product, PM TJU see what he thinks
    7 years ago
    Quoting Chaser on 20 Aug 2018 04:55 AM
    Sent you a PM
  • STROPP
    STROPP
    7 years ago
    I have the advan black one, just did Perth to Darwin and back via pt Augusta 9987k no problem at all and colour matched too for $1000, great value
    7 years ago
    Good value
  • steelo
    steelo
    7 years ago
    That came out well Stropp. They are not cheap but look good. I thought they only did the cut down models
  • dyna13
    dyna13
    7 years ago
    Quoting STROPP on 27 Aug 2018 09:31 AM
    Looks good Stropp was the price with top rack and lower detachables ?
    7 years ago
    Quoting steelo on 27 Aug 2018 09:47 AM
    Cheaper than gen HD from the dealer
  • dyna13
    dyna13
    7 years ago
    Quoting paulybronco on 27 Aug 2018 10:50 AM
    Think it was about $2000 if I remember right
  • STROPP
    STROPP
    7 years ago
    $2500 for genuine ????
  • STROPP
    STROPP
    7 years ago
    Quoting dyna13 on 27 Aug 2018 10:43 AM
    No mate both extras just the box
  • Chaser
    Chaser
    7 years ago
    Primed only genuine $1085. Then add lights locks, backrest etc. Depends if you want lights or not as theirs don't come pre-drilled.
  • steelo
    steelo
    7 years ago
    Hi Chaser. This just came up on Gumtree in South Australia. A 2014 Ultra top box with speakers it seems. Pricey though at 2K
    7 years ago
    Yep thats pretttty pricey
  • Chaser
    Chaser
    7 years ago
    Quoting paulybronco on 27 Dec 2018 01:40 AM
    Pretty sure that includes an expense free trip to SA for the week to grab it!!!
    7 years ago
    Quoting Chaser on 27 Dec 2018 02:00 AM
    LOL Not to the painting, freighting etc . NO DEAL!!
