Online:
baldy1450
Super Tuner Pro Maps
Sparra
7 years ago
My young bloke has a 2011 Softail that came with a Screaming Eagle Super Tuner Pro...Apparently there is a site that has maps on it for down load,any one know what it might be?
Cheers...
R2D2
7 years ago
I think you plug the bike to the tuner and a lap top to the Screaming Eagle program/site and type in your VIN and it will show you the maps.
Not a hundred % sure though .
Ratbob
7 years ago
Unless you’re thinking of a non Harley site, (hope so cause I’d like to know about it too) download the Super Tuner software and there’s a swag of stock tunes available. Unless the softwares changed since I downloaded mine, you can search the tunes without buying the cables, just can’t flash em to the bike.
Sparra
7 years ago
Thanks fella's...yep I downloaded the program and found them all...Just trying how to turn on Auto Compression Releases on..
Ken in Cairns
7 years ago
Open the software and after you load your map, look down the list on the right hand side, were the AFR,VE and spark tables are etc.
The last line is called Tuning Setup.
Open that one and the last tab on the right is the ACR tab, open that and see if it is currently on or off.
The selected option is black with a white ring, the non selected one is a solid white dot.
If it isn't enabled, enable it and re-flash the bike as per usual.
The ACR's will now be turned on.
Hope that helps.
Cheer
Ken
